276 SSX Night Lights
Here are some pictures of the Blue LED's that I had installed on my boat. I read through all of the posts about which LED lights to use in the Radar Arch and I basically kept an open tab with superbrightleds.com working with the right type of LED bulb for the courtyard lights. I had also picked up my a replacement Radar arch lamp set from imtra.com, I also used courtyard exterior housings from a very affordable resource - www.replacementboatparts.com
1. Courtyard and dash lit up.
3. From Swim pad entry
4. BI Color LED's in the Radar Arch
5. Typically you can switch between Blue and White for both, but if you can time it right you can get one white and one blue.
Also I have updated all of the Nav lights to be LED, of course the pictures are pretty horrible. But you can get the idea. Note - I went with Cool White LED's for the new Tower light along with a 31mm X 10mm Cool White LED Festoon bulb for the stern light.
- RZRBCKCHAP
