Sharon Goldin
183 ssi overheating
Can anyone comment on 2003 183 ssi that is overheating when trying to pull skier for longer then 2 min.
The impeller has been changed, the thermostat has been changed.
The thermostat housing has been changed.
I did find a piece of impeller from previous changes in the thermostat housing, and not sure if there were more pieces missing.
I had something like this happen on my 180ssi. It would run fine and then as soon as I pulled a tube, it would get hot and the alarms would go off. It ended up being that I didnt' get the cap for the water flush on good and I guess it wouldn't create enough suction to get enough water. Put the cap on correctly and tight and problem went away.
did you install your own motor fush?
How long have you owned the boat ?
How long have you noticed the problem ?
Is the time to overheating about the same for as long as you have noticed ?
What engine size / Carb or F I ?
What is the prop ? # of blades, diameter , pitch, prop company ?
Do you has a G P S accurate speed of the boat with just you in it ?
Does the boat accelerate quickly to a full plane speed ? How many seconds to get on a full plane.?
What is your water temperature at idle when warmed up ? Water temperature at W O T alone in the boat ?
Did this problem start after sending your prop to a prop shop for some rework ?
There are many reasons for overheating.
