VeeThree Gauge Problem
Boat information:
2010 Chaparral 290
Twin Bravo III 4.3L MPI
These V3 gauges are driving me crazy. I have had them replaced several times due to fogging issues and the problem continues.
I was winterizing the boat on Friday and noticed that when I ran the starboard engine, the following occurred:
Multi function digital gauge - works normal
Port gauge - no reading except voltage
Starboard gauge - no reading except voltage
I was getting no indication of oil pressure, temperature and engine trim. However, when I ran the port engine, the following occurred:
Port gauge - normal reading
Starboard gauge - showing port engine parameters
For some reason, the port engine parameters are shown on both engine gauges. Has anyone had this issue? Does anyone have wiring information for V3 gauges? Any ideas????
Mike
This is who I have spoken to at Vee Three about my issues in the past.
Marcin Maleszka
Technical Support Representative
Veethree Electronics & Marine LLC
2050 47th Terrace East
Bradenton, Florida 34203 USA
Phone: 941.538.7775 ext. 350
Fax: 941.755.1222
OK... Problem solved. Called Marcin and he informed me that the gauges are hard coded as Port and Starboard. Turns out I have 2 port gauges. Go figure!!!!
The warranty is with Vee Three, not where you bought the boat. I have had the gauges replaced multiple times because of the fogging issue. Vee Three just had me deal with a local marina to do the work since the place I bought the boat from was far away. Vee Three warraty is 4 years, but only 3 years with Chaparral, so if your boat is over the 3-year warranty period you are on your own.
I called vee three directly to see if there was a recall on the gauge. I remember reading in another post about a recall on the gauges. When I called them and another Chap dealer that has since opened up in my town, I was advised there was no such recall. I took photos of the gauge fogged up and I even went as far as pulling it out of the dash to check the serial number on the back of the gauge.
