Four Screws Posted March 7, 2013 Share Posted March 7, 2013 Hi, again friends. A little problem wanted to run past everyone before I took further action. My cabin isotherm frig in my 2002 350sig all of a sudden stopped cooling. Has worked great prior and had the temp set in the middle and it was nice and cold. Came back this past wknd and it was hot, food...well not good anymore...i may be able to salvage the beer. Lol. Fan is working/running and clean just not cooling? Not sure if it is the thermostat or the compressor just died. Not sure how to check either or if it's another problem. I will take any suggestions. Thanks. Quote Link to post Share on other sites
alka2710 Posted March 7, 2013 Share Posted March 7, 2013 Isotherm has great tech support, give them a call. They have a heavy Italian accent.Al Quote Link to post Share on other sites
Baum's aweigh Posted March 7, 2013 Share Posted March 7, 2013 Usually when you have blowing air but not cold air, the system has lost its coolant. That is usually caused by a system leak or a compressor on its way out. Sometimes you can just re-charge the unit and you're good to go but on a 11 year old frig, more than like the compressor is gone. leaks are caused by a hole in the system, and are hard to fix. Repairmen can re-charge with a dye. As it leaks out, the dye leaves a mark so you can find the leak. Often, the leaks are in the cooling coil or evaporator coil. It may be time for a new unit as the cost to repair may exceed the cost of a new one.Al Quote Link to post Share on other sites
mpm330 Posted March 7, 2013 Share Posted March 7, 2013 Isotherm should be able to tell you how to test to see what has failed. I know several owners that have Isotherm refrigerators from around your model year and they have all had to replace the thermostat. Something about getting water in them and needing to beter sealed. Quote Link to post Share on other sites
livingwater Posted March 9, 2013 Share Posted March 9, 2013 Any HVAC service company should be able to troubleshoot and hopefully make repairs.The refrigerator is over 10 years old.You may want to consider upgrading to a newer more effecient unit. Quote Link to post Share on other sites
The Great Escape II Posted March 9, 2013 Share Posted March 9, 2013 Any HVAC service company should be able to troubleshoot and hopefully make repairs.The refrigerator is over 10 years old.You may want to consider upgrading to a newer more effecient unit.Do you have any idea how much those units cost? A replacement for his 350 will run him from 1200 deer to 1600 deer. There has not been any technology changes on these units in years and he will be able to find the exact replacement. The only major change they have done is an updated door lock mechanism. They not like home units on energy efficiency. Quote Link to post Share on other sites
The Great Escape II Posted March 9, 2013 Share Posted March 9, 2013 Isotherm has great tech support, give them a call. They have a heavy Italian accent.AlThey have an office in South Florida. They sent me a replacement stainless steel door that had a defective latch, great service. Quote Link to post Share on other sites
Iggy Posted March 9, 2013 Share Posted March 9, 2013 Do a voltage test at the frig with it on and check all the connectors that they are clean. What can happen is a voltage drop due to corrosion. Quote Link to post Share on other sites
cyclops2 Posted March 9, 2013 Share Posted March 9, 2013 Call a refrigerator repairman. He will test the obvious things without damaging the boat.You can do more damage & possibly hurt your self. Quote Link to post Share on other sites
livingwater Posted March 10, 2013 Share Posted March 10, 2013 Do you have any idea how much those units cost? A replacement for his 350 will run him from 1200 deer to 1600 deer. There has not been any technology changes on these units in years and he will be able to find the exact replacement. The only major change they have done is an updated door lock mechanism. They not like home units on energy efficiency. I do nowOuch! Quote Link to post Share on other sites
Four Screws Posted March 10, 2013 Author Share Posted March 10, 2013 Thanks for the replies. I think it is a leak bcs I see coolant residue dried coming from the main tube. Bought JB Weld(3900 psi strength) and covered it. I may need a recharge and I heard that could be tricky doing myself. Will take to shop and have them do it to save on cost. If that doesn't fix a new on may be in my near future. Quote Link to post Share on other sites
gl115 Posted March 10, 2013 Share Posted March 10, 2013 Any ac or refer unit I have ever sealed for a leak I would use leak seal or silver solder, then vacuum out and fill with nitrogen and check for leaks using a gauge and a black light, JB Weld does not have the same expansion rate and makes it a pain to clean off enough to seal the leak properly. Quote Link to post Share on other sites
Iggy Posted March 10, 2013 Share Posted March 10, 2013 I do nowOuch!Most of these units run on D.C. 12v. They have inverters built into to them and they can to fail. I should have asked this question first. Does the fridg have the same problem on A.C. and D.C.?? Quote Link to post Share on other sites
livingwater Posted March 10, 2013 Share Posted March 10, 2013 http://www.youtube.com/user/partselect?v=wqOzCQWoqxw Quote Link to post Share on other sites
Scani6 Posted March 11, 2013 Share Posted March 11, 2013 Our fridge went warm last year. Talked to a repair man before the fix. With parts and labor, it would have been $ to repair. We weighed the options, and spent the $ on a new Norcold. We figured, the fridge made it 15 years, and had served it's time. Plus, the new fridge is way more efficient!Weigh your options! Quote Link to post Share on other sites
Onefastaudi Posted October 4, 2015 Share Posted October 4, 2015 Anybody can give me the size of the fridge on the 350 sig? (2002). Ours quit. Boat at dealer 400 miles away. Need to do some pricing research. Thanks Quote Link to post Share on other sites
