Hawkins8810 Posted April 27, 2013 Share Posted April 27, 2013 I own a '95 Chaparral 1930 SS Sport. Boat was winterized at the end of last season, now the first time I put it in the water it will not turn over. Took the battery to an auto parts store and it tested good. When I try and start, it makes one click and will not turn over the engine. Is there any way to test the starter or see if the engine is seized up? Thank you in advance for any suggestions or advice. Quote Link to post Share on other sites
2strokemerc Posted April 27, 2013 Share Posted April 27, 2013 Does the starter operate or is it just the relay clicking. You could pull all the spark plugs and try cranking it but I would turn the engine with a wrench first if you think it's seized. Perhaps one of the cylinders is filled with water. I've turned a v8 with just my hands by pulling on the belts and pulleys, could be done if you don't have the appropriate tools. Quote Link to post Share on other sites
cyclops2 Posted April 27, 2013 Share Posted April 27, 2013 Do you have & know how to use a simple voltmeter ? You will need one. Quote Link to post Share on other sites
The Great Escape II Posted April 27, 2013 Share Posted April 27, 2013 Have you checked your kill switch? Quote Link to post Share on other sites
tomnjo Posted April 28, 2013 Share Posted April 28, 2013 Try tapping on the starter solenoid while someone else holds the key. It may be sticking. Use the handle of a large screwdriver or a small ball pean type hammer. Just a tap, If the boat was winterized it was probably fogged while runnng on muffs. I don't think it would have ingested water. Quote Link to post Share on other sites
gl115 Posted April 28, 2013 Share Posted April 28, 2013 http://easyautodiagnostics.com/bad_starter_test/starter_oncar_tests_1.phpnot a boat but same principal. please wear safety glasses, you only get 2 eyes. Quote Link to post Share on other sites
brayday Posted April 28, 2013 Share Posted April 28, 2013 check your grounds to the battery. Clean them make sure they are properly attached. Quote Link to post Share on other sites
Entee Sublett Posted April 28, 2013 Share Posted April 28, 2013 Like one fine gentleman said, first try to turn your engine over by hand, honestly I wouldn't even pull the plugs out. You will be able to overcome the compression. Make sure you get a full revolution. If not then you may have mucho problems. But probably the starter or bad connections!No big deal! And hello fello 1930ss owner!!!!!!! I've done all kinds of stuff to mine. So if I can help you ill do my best! Quote Link to post Share on other sites
Entee Sublett Posted April 28, 2013 Share Posted April 28, 2013 Obviously turn it with a break over bar on balancer bolt!!! Lol not physically with your hands. Unless you have a bear's grip! Quote Link to post Share on other sites
Hawkins8810 Posted April 30, 2013 Author Share Posted April 30, 2013 Thank you all for your replies, it is greatly appreciated!I tried the tapping trick and it did not work. The kill switch is in the run position, it was in the off position at one point the other day, but I switched and still had the same issues.I do have and know how to use a voltmeter, but I looked at the link gl115 posted and I'll let the experts test that. I also do not feel comfortable pulling plugs or cranking manually.I will check the ground connection and see what I find out before my appointment with the mechanic later this week.Entee I'm hoping that it's as easy as a bad starter or connections! We just got the boat at then end of last summer and it only has 342 hours on it, ready to put it in the water.Thanks again. Quote Link to post Share on other sites
Iggy Posted April 30, 2013 Share Posted April 30, 2013 check your grounds to the battery. Clean them make sure they are properly attached.Back to basics, as in the above post. Also check the POS cables too. You may have a cable going bad, more if you have copper cables rather than tinned cables. The copper cables turn green inside and do not let enough current though. Quote Link to post Share on other sites
96Chappy Posted May 4, 2013 Share Posted May 4, 2013 Hope you got it figured out. Its not that hard to turn the motor over by grabbing the belts. You really cant get hurt or damage anything and if it does turn you should be ok. I had an issue with that one year on the first start up of the season because of winterize issues. Good luck...... Quote Link to post Share on other sites
Hawkins8810 Posted May 4, 2013 Author Share Posted May 4, 2013 Hey guys thanks for all the replies. I just picked up the boat from the mechanic today. There was water in the 6 cyl, he was able to drain, fog and fire it up, all is good (luckily). Spark plugs replaced (original from '95), outdrive serviced and water separator replaced.Ready for boatin' season here in KC, just had snow on May 2nd!!! Quote Link to post Share on other sites
tomnjo Posted May 4, 2013 Share Posted May 4, 2013 But..............why was there water in there?? Quote Link to post Share on other sites
gl115 Posted May 4, 2013 Share Posted May 4, 2013 water in a cylinder is bad,like asked above why? I would keep an eye on that. Quote Link to post Share on other sites
Jacksonwest Posted October 29, 2020 Share Posted October 29, 2020 In my opinion, you must have the basic tools regarding the boats so you can diagnose the issues. The automotive multimeter is one of them which helps to diagnose the electric problem easily and quickly. And it is easily available in the markets at an affordable cost. But the question is which is the best multimeter available in the market for your vehicle or boat. So I provide you the details where you can easily compare the best multimeters in the market, for this you can visit https://handtoolsforfun.com/top-5-best-multimeters-for-diy-electronics-and-repairs to compare and know more about the multimeters. Quote Link to post Share on other sites
Bt Doctur Posted October 29, 2020 Share Posted October 29, 2020 I think after 8 years they figures it out. And you spammers should just die off and go away already. Your useless to society. No need to dredge up old posts Quote Link to post Share on other sites
Phillbo Posted October 29, 2020 Share Posted October 29, 2020 No need to reply to bots either....... Quote Link to post Share on other sites
SST Posted October 29, 2020 Share Posted October 29, 2020 How much to these jerks make to spam everything? Quote Link to post Share on other sites
cyclops2 Posted October 29, 2020 Share Posted October 29, 2020 It is found money to them. WE do ALL the work if we are interested. Quote Link to post Share on other sites
