Chaparral1
Identifying Battery 1 & 2
My '07 256 ssi came with 2 Starting batteries. Will replace them with a Starting battery on Perko switch location #1 and a Deep Cycle on #2. How do I identify which set of cables is 1 or 2? They're not marked niether is the back of the switch. Is it as easy as following the wire coming out of the side of the switch that is in #1 location?
Switch to #2, put some serious load on your house battery, and use amp clamp to check which of the positive battery cable carries the current ... or simply disconnect the batteries one at the time and see which one takes the house down.
Just disconnect one set the switch to #1 or #2 and try to start it. You'll figure it out real quick.
