flostalo Posted June 25, 2013 I have a 2004 234 Sunesta with a 5.7 volvo penta single prop.I mostly run it at Lake Powell (5000 ft) I have two props : a 3 blade (aluminum)14 1/2 x 19 pitch, this prop is slower out of the hole , unless there's very few people , light load, then it ok.This prop has nice end speed(or so I think) at 43 mph at about 5k rpm.The engine seems quieter also.Then I have a four blade 15 inch X 16 Pitch (aluminum)This prop is of course better out of the hole, noisier engine, lower end speed 38mph or so.Better with heavier loads , 10 people or so.I want to experiment see if I can get a better than this two props, a happy medium.My idea was to get a lower pitch on the three blade -a 14 1/2 X 16P , and /or a higher pitch on the 4 blade ,a 15inch x 17 pitch. Is this the right direction? Any better ideas? How does the size of the prop affect speed, torque? We usually have two adults and four 10-13 year olds aboard but often have 7-8 people wake boarding .I would appreciate any input in the matter and also best prop dealer info for better piecing;Thanks in advance, Fernando Quote Share this post Link to post Share on other sites
216RENO Posted July 25, 2013 If lake powell ever reaches 5000 FT Las Vegas will be under water ! Quote Share this post Link to post Share on other sites
