no power at ignition switch
We have a 1994 Chaparral 1830 SS. It's a great 18' speedboat with a bow rider.
I was trying get it started. It was cranking over and then just stopped responding to the key being turned. I checked the usual suspects like the kill switch, the throttle being in neutral, the battery being alive - all good. I then tested the wires going to the ignition switch and none of them have power. The blower has power. The horn has power. Everything in the dash is powered up except the ignition switch.
It feels like some safety switch is off somewhere. I attempted to disassemble the quicksilver 3000 throttle, but just made a mess. The main piece fell into the cavity behind the bulkhead and I'm no closer to seeing any wires connected to it.
Does anyone have any clues or suggestions about where I can start debugging the problem? Without a wiring diagram, I don't know where to start. Power is lost somewhere between the ignition switch and the dashboard. Any suggestions on common failures in a 19 year old boat?
Any suggestions of what to do or people to consult would be greatly appreciated. I'm in Stockton, California.
thanks,
Peter
