buzzman Posted November 1, 2013 Share Posted November 1, 2013 HelloWent to winterize boat today and drain port side of engine block through the raw water drain. There is a wire attached to the drain so I am not sure how to drain it as easy as the starboard side which was a brass fitting. Any suggestions please? Quote Link to post Share on other sites
Lowflyer Posted November 3, 2013 Share Posted November 3, 2013 I have the same boat. Mine has a 5.7 VP but no wire attached to a drain.What engine and do you have a pic?Cheers, Quote Link to post Share on other sites
951Tom Posted November 4, 2013 Share Posted November 4, 2013 Sounds like the knock-sensor. Some models use them as the drain plugs. Unplug the wire, then unscrew the sensor to drain the block. When tightening, the torque is critical so you'll need a torque wrench. 12-16 ft lbs. Quote Link to post Share on other sites
