nkdenton Posted April 11, 2014 Share Posted April 11, 2014 Apparently I'm still several names down the list for a dry rack at the marina so looks like another season trailering.Anybody got any experience or opinions on this device?http://www.thmarine.com/products/Boating-Accessories/Trailering-Aids/Sterndrive-Trailering-Clips Quote Link to post Share on other sites
Futzin' Posted April 11, 2014 Share Posted April 11, 2014 You don't need 'em . . . won't hurt anything though Quote Link to post Share on other sites
cyclops2 Posted April 11, 2014 Share Posted April 11, 2014 Why is it I think a 200 to 600 hp drive, loading & unloading at WOT puts more strain on the transom & cylinders, than a short drive unit with cylinders full of oil ?Fear always out sells logic.O K . Fear & sex outsell logic.At 76. I am afraid of both. Quote Link to post Share on other sites
Toddler Posted April 11, 2014 Share Posted April 11, 2014 Some guys use them, Its a peace of mind kinda thing. I dont use them and I travel a lot. Quote Link to post Share on other sites
Richard W Posted April 11, 2014 Share Posted April 11, 2014 You don't need 'em . . . won't hurt anything thoughMe thinks alike ... I do have them, and started using them for trailering ... just in case.The similar (same?) product is sold under Sierra name, just make sure it fits your drive.There are different models for Merc and Volvo: http://www.amazon.com/Teleflex-Marine-18-9098-Trailering-Clip/dp/B001BWCG6M/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1397186509&sr=1-2-fkmr1&keywords=Sierra+International+Marine+Trailering+Clip Quote Link to post Share on other sites
Denny Posted April 11, 2014 Share Posted April 11, 2014 It is like an insurance policy, you hope you never need to use it, but they act as a safety net and will stop your out drive from hitting the pavement, should you ever loose your hydraulics. Like Matt says, it's a piece of mind thing. I have them, been trailering since 92, never needed them. Word of advice, if you get them, don't forget to remove them before you launch and lower your out drive, been there, done that. Denny. Quote Link to post Share on other sites
krmartonik Posted April 11, 2014 Share Posted April 11, 2014 It is like an insurance policy, you hope you never need to use it, but they act as a safety net and will stop your out drive from hitting the pavement, should you ever loose your hydraulics. Like Matt says, it's a piece of mind thing. I have them, been trailering since 92, never needed them. Word of advice, if you get them, don't forget to remove them before you launch and lower your out drive, been there, done that. Denny.My thoughts exactly. Including the last part Quote Link to post Share on other sites
gl115 Posted April 11, 2014 Share Posted April 11, 2014 I use them and transom savers all the time, cheap insurance from draging a skeg. Quote Link to post Share on other sites
cyclops2 Posted April 11, 2014 Share Posted April 11, 2014 Best reason there is. If your system leaks down over time.Good one gl. Quote Link to post Share on other sites
beason Posted April 11, 2014 Share Posted April 11, 2014 for short trips, id say they arent needed. as long as your drive stays up overnight or the week its sitting on the trailer, it should last to the ramp.now if you are trailering a long distance, id say its cheap insurance. if that lower dropped and was hitting the ground, you would likely never know it. at least until someone flagged you down. Quote Link to post Share on other sites
gl115 Posted April 11, 2014 Share Posted April 11, 2014 Theoretically? most times the skeg decides to lower itself when its being trailered is because there is a loose wire in the transom up / down switch that makes contact and because of murphys law always lowers it to the ground. by the time u see the sparks in the mirror its 2 late, u can rewire the switch ( thats what I do) to prevent this but then u need 2 turn on the batt. switch 2 raise or lower the outdrive, its impressive what concrete at speed acting like sandpaper can do to aluminum. 2 me its just another step like undoing the tie down straps and making sure the plug is installed, u will in time forget the plug but most only do it once. and while I'm ranting its also like towing with an undersized tow vehical, u will get away with it until somthing happens like loss of brakes during a panic stop, then the law and insurance co. will crucify u, but thats the decision u made and will have to live ( hopefully ) with, u can add airbags to your shocks etc, but CGVW is what it is. Quote Link to post Share on other sites
steveobrien84 Posted April 11, 2014 Share Posted April 11, 2014 20 deer for piece of mind well worth it. Quote Link to post Share on other sites
MonkeySeaII Posted April 11, 2014 Share Posted April 11, 2014 I use them just in case a hydraulic leak ever develops and the drive starts to creep down. Cheap insurance. Quote Link to post Share on other sites
Jjlai724 Posted April 11, 2014 Share Posted April 11, 2014 I use them as well. You can make your own out of PVC conduit as well. Electrical PVC Schedule 40 will fit. Quote Link to post Share on other sites
nkdenton Posted April 11, 2014 Author Share Posted April 11, 2014 Why is it I think a 200 to 600 hp drive, loading & unloading at WOT puts more strain on the transom & cylinders, than a short drive unit with cylinders full of oil ?Fear always out sells logic.O K . Fear & sex outsell logic.At 76. I am afraid of both. Quote Link to post Share on other sites
cyclops2 Posted April 12, 2014 Share Posted April 12, 2014 Tough times many decades ago. I am coming home with a 16' aluminum fishing boat FILLED with a week of everything from staying at a cabin with the wife & daughter in a 1974 ? Honda Civic. First ones in the USA. There had to be at LEAST a 1500 pound added weight to the stopping load.Come around the blind curve. There is the 1 lane bridge.150', away. Doing 25? Car coming the other way. I am pulling the steering wheel up so hard My biceps are stinging. No braking at all.Other car had enough brains to see I was not slowing down.Cyclops moral of life is.Better to have lots of luck. Than lots of brains. : Quote Link to post Share on other sites
