nkdenton
Where's the ground under the helm
I see the yellow terminal block for 12v + connections. I'm assuming I can pull power for my AutoGlide controller off that bus as long as I protect it with a properly sized inline fuse. Am I correct? Does the plastic cover just pop off the screws at each end?
The Chap wiring diagram in the owners manual shows a ground bus near the engine compartment - Is there a similar ground bus or common ground at the helm as well?
Thanks in advance.
Also, any tips for how to re-wrap that rats nest of wiring and harnesses under the helm greatly appreciated....of course I'm expecting it to just be brute force.
