Crued
Vacuflush light on, no flush.
Finally got some water in the tank and went to try vacuflush, but got no flush. The switch is lit when on, but I don't hear anything and assume I should. I left it for at least 10 min, and still no vacuum. The bowl appears to hold water just fine, but it doesn't go anywhere at all when the pedal is depressed.
I have no idea where to begin diagnostics. I assume the issue is with the pump or something electronic related to the pump's systems, but which one to start with?
I had the same issue and it turned out to be the pressure switch. Many times they just don't turn off, but mine never came on. Instead of replacing the entire vacuum switch assembly, I googled the electrical part on the top of the assembly, the actual switch, and got it for 1/3 the price of the whole assembly. Started to take it apart and found it was just stuck. Still using the original, but now I have a spare... Good Luck! Greg
Thanks, sounds easy to check. Picture would be worth a thousand words on this one for sure!
Dumb question... where do I find the vacuum generator to begin with??? The illustration seems to show it being forward of the bilge, and the parts list picture I see raw 'glass, so I'm not sure where that could be.
vg2.jpg?t=1398725710
ITEM PART NO DISCRIPTION ITEM PART NO DESCRIPTION 1 385311323 PUMP COVER KIT 13 385310540 VACUUM SWITCH ASSEMBLY (includes 11 & 12) 2 385311423 12 V MOTOR UPGRADE KIT
(includes 2,4,5,6,7&22) 14 600347802 DUCK BILL VALVES (4 required) 385311424 24 V MOTOR UPGRADE KIT
(includes 2,4,5,6,7&22) 15 388640366 1 1/2" CLOSE NIPPLE 3 385311324 PUMP TOP CLOSURE 16 385311163 HARDWARE PUMP TO TANK 4 385310151 "O" RING KIT 17 385310635 INLET ELBOW KIT (includes item 18) 5 385310242 BUSHING 18 600342932 1 1/2" SEALING GROMMET 6 385310644 ECCENTRIC KIT 19 600347800 VALVE NIPPLE 7 600347807 BELLOWS CLAMP (2 req'd) 20 600347801 VALVE ADAPTER 8 600342783 3 3/4" HOSE CLAMP 21 385311844 PUMP BODY 9 600342779 O'RING, 3"ID X 3 1/4" OD 22 385230980 BELLOWS ASSEMBLY (includes item #5) 10 385310539 DIPTUBE ASSEMBLY (includes 9) 23 385311215 VACUUM SWITCH COVER 11 600342782 2 1/2" HOSE CLAMP 24 385311318 MOUNTING SPINDLE 12 600342778 O'RING 2"ID X 2 1/4"OD N/S 385310774 VG 2 PUMP ASSEMBLY COMPLETE 12 VDC (INCLUDES 1-7,14,15,19-22 385314775 VG 2 PUMP ASSEMBLY COMPLETE 24 VDC (INCLUDES 1-7,14,15,19-22
I'm guessing yours looks something like this......
It should be right on the holding tank.
just got done rebuilding ours.
Replaced duck valves(4) plus the plunger and diaphram. and a seal kit.
The duck valves should be replaced every 3 years they said(vacu flush people) we have 9 years on ours.
plunger replaced with a new up grade which was smaller than the original few phone calls but its a well now mama is happy.
Well, I have some updates for those that will find this via search...
1). The vacuum generator on my 05 Signature 270 is behind the cabinet in the aft berth. Take out the cabinet by removing the 4 screws inside it.
2). To test the vacuum switch, jumper B to B connection on the limit switch which sits atop the vacuum switch. B is the contacts that are open when the plunger on the limit switch is out, ie: time for pump to stop..
3) Limit switch part number is 9007AO1 and runs about 40 deer.
As you can see below, one of the B contacts on my limit switch broke. The system worked when jumpered, so I have high hopes for a simple replacement of the limit switch.
post-40779-0-63112000-1406676344_thumb.j
post-40779-0-42669800-1406676973_thumb.j
