Foghorn
Fusion MS-BT100 cutting in and out
Anybody have trouble with their Fusion blue tooth cutting in and out?
I plugged the RCA's in and hooked up the power.
I don't have a Fusion head unit. Could that be causing it?
I think I have a JBL unit. I'm pretty sure it's stock.
I have the Fusion BT100 on my CHaparral 264 with the Clarion head unit. It has worked flawlessly, BUT..occasionally a device will not be able to connect, even though the Fusion network is seen under the "Bluetooth" settings. The only solution is to Delete the Fusion Bluetooth acct and then power down the device (my phone, etc.) and the repower up and let it discover the Fusion again. I then can connect without difficulty. Doesn't happen frequently.
My Blutooth "antenna brick" is inside the cabinet under the stereo and can pick up devices all over the boat...rare to no cutouts.
Mike
Check your connections
My Fusion BT unit is connected to my Clarion head unit. Other than the annoyance of having to reconnect a device after starting the engine, no issues.
