Hatem
What are some cool modifications you've done to your boat?
On ‎10‎/‎28‎/‎2018 at 7:30 PM, Dennis A said:
At least it wasn't the props and the bumper...that would be expensive.  ^_^  Are you going to replace or re-use the anodes?
You're 100% right, that was the first thing I panicked about was whether it was the drive and props that made contact and not the SP.  BTW, speaking of props, notice anything wrong with them?  @Curt, we were having this discussion about a month ago.  :D
Would you reuse that anode?  I bought new ones but just curious how long one can go with those?
1 hour ago, Rip5 said:
168.324 hours remaining......;)
Wise guy. :)  I was just wondering if people actually reuse those if they haven't been eaten up much.  Get more use out of a $40 item.  Unless it's pretty much cooked.
On ‎10‎/‎30‎/‎2018 at 2:28 PM, Curt said:
Can’t see anything on the pic.
Check out my perfect timing of the props LOL! :D  I was very disappointed at myself when I noticed that as soon as we came up the ramp.  I couldn't have lined the two props and their blades under the cavitating plate any better than that.   :haha-7383:
Rule of thumb is replace when about 50% remaining.
Good to know, thanks.  I already bought new ones but I might reuse these since they're way less that 50%.
Oh,  I was looking for damage.
Fortunately I was to the right of the truck a little bit.  But I'm a little perplexed as to the timing since I was almost positive I lined them up correctly prior to splashing her.  I went back and looked to be sure and found proof positive here.  This was the day we launched after 6 or 7 coats of sprayed Trilux .  Wonder if the outer prop shaft is spinning at a different RPM than the inner one?  That's almost impossible, though, with the way the propshaft gears are designed.   Mmmm….:scratchchin:
@Roady68, did you find the remote for the Pronautic 2130 charger yet?
The props are contra-rotating.  It's just a matter of chance they lined up when you took it out of gear.
True, but if I lined the forward prop with one blade in the 12 o'clock position and the outer prop in the 6 o'clock position like in that pic above, they should never line up under the cavitating/exhaust plate no matter when it's taken out of gear.  I'm starting to think that maybe that isn't the pic from the beginning of this season.
I haven't ordered it yet.  I found the jack on the charger and I have a spot picked out where I want to mount it.  Boat is in storage so I don't have access until spring.
Cool.  Thanks for replying.  Keep me posted if you don't mind.  I'm getting ready to pull out the old charger and throw this one in, probably this weekend when I winterize and pull out the batteries.  I'll test it in the springtime when I reconnect them.  I need to find a better way to install this new charger because the current one is facing sideways inside the wetbar storage locker.  It's a great location since it's very close to the battery switches and by facing it that way, it gives me more room in the storage compartment.  But I need it facing outwards to see its indicating lights etc. a bit better.  Not sure if that's possible but will certainly try.  That locker area (which is basically trash bin and paper towels and some oils/cleaners etc. is very valuable space.
Would you fix this, or just leave it alone?  Haven't had any issues so far in 5 years and I'm usually a firm believer in "if it ain't broken, don't fix it" and never noticed this at all until winterizing yesterday and when I took the boat to the gas station to fill her up, I'm watching the gas fill up in the tank and looking around at everything including the gas fill hose and vent line and I noticed this dip in it.  It goes down and back up to get past the cockpit drain hose.  I'm sure there's a bit of gas that gets trapped in that dip once I stop filling up, but not sure it's a big issue.  I guess when the boat is rocking in the water I'm sure whatever bit of gas sitting in that dip ends up being pushed into the tank...but it did bug me a little.  Funny how I never noticed it before with all the hours I've spent in that bilge.  I think running it above that drain hose would be better.
 It shouldn't be a problem for you. I'd leave it
Going on my own past experience do not let any gas settle in the fill hose and the vent hose, eventually it will deteriorate them. They both should be above the top of the tank. It looks like all you have to do is move them above the other hose, or move the other hose under them. 5 minutes of your time now, may save you future headaches. Denny.
+1.  At least you don't have tear up the floor to get at it like Denny did.  The bend radius on the 1" line tee'd into the drain line looks a little tight too.
I was thinking the same thing as you, ma man.  But it sounds like you and I might be in the minority on this.  Man, I'll tell you what; it's one thing to drill a wrong hole or mess up a little fiberglass in the bilge, but this here sucks royally.  Next time I'm in there I'll take a better look at the condition of that hose on the bottom of that dip.  Last thing we want is gas leaking out of that all over the place.  Hopefully others reading this triggers them to take a look at theirs and see if they have anything similar to this disaster so they can fix it before anything happens.
New product by Pettit antifouling paint.  Supposedly environmentally safe and COPPER FREE and you can actually apply it over any existing bottom paint you might already have.  Just out and being tested by boating industry critics.
Raymarine has come out with a new GPS, RealVision 3D sonar.  You can see the shaping of the bottom in 3D and also helps you judge what direction you're looking at it in relation to the boat.  Something I certainly struggle with my Garmin and conventional sonar/fish-finder.
DjCXm0yXgAAJ3hT.jpghttps://www.boatingmag.com/raymarine-realvision-3d-sonar?src=soc&dom=tw
This thing is pretty cool if you're adding a bunch of mods to your boat and you want to control them from a single, main panel but I think it's only up to 6 items.  That's still good, 6 less switches you have to install or look for and reach.
Power-Poile Vision. https://www.boatingmag.com/power-pole-vision?src=SOC&dom=tw
Here's an old-fashioned mod for those of you who want an easy way to drain that pesky, leftover bilge water.
21558902_1643003255770657_24994365916302
:haha-7383:
42 minutes ago, Denny said:
Back in the day had one of these on my 14 ft Wolverine.  Denny.
Those things scare me.  Little bit of debris holding the flaps open...down she goes.
At that time in my life,1958 safety was not a word that we knew, these were our heroes.  Denny.
th?id=OIP.M-FzNbpGft7lHsSFi1rhegHaFk&pid=15.1&P=0&w=225&h=169
What is that?  Obviously a butt plug but with fins that spin or something?
The 50's was such a great decade, coming off of WWII, not just the US but practically the entire world had a monumental technological boost in every single field, engine technology being arguably the biggest advancement particularly the jet engine.  While it was invented in the 40's, it wasn't really successfully applied until the 50's. along with so much other technology.  The happy decade.
I'm replacing the carpeting on the boat and wondering about the beachweave.  Anyone who has it, can you comment on if you like it?  Does it drain and dry out better?  How comparable is it to berber?  We really like the feel of the berber but the usual problem of the rubber backing is starting to fall apart and this place has the exact pieces ready to go and the price is VERY  reasonable.  https://www.snapincarpet.com/ecommerce/Chaparral-276-SSX-07-09-.cfm?item_id=338&parent=652&navPanel=
@Curt, you have the beachweave, right?  Do you like it?  What about the faux teak on the walkway and swim platform, does that get hot?  I'm thinking of doing that exact teak on the walkway only since I don't really want it on the swim platform (might change my mind on that) but definitely on the walkway because that takes a lot of traffic and wearing and I think the teak would be better.  Do you have a good pic of it?  How thick is it?
(1) Beachweave. In my opinion, it's nicer than the traditional berber. Cleans far easier, cooler, and doesn't have a "cottony" "nap" that collects bad stuff.
(2) Faux Teak. A view and another opinion or two. It's hotter than he-double hockey sticks when in the sun. The light gray SeaDek on the 264 didn't get hot. The faux teak, no socks, no shoes = discomfort. Get it wet, no problem. It's in two areas... swim platform and transom pass-through. In addition, I added it to the anchor cover so the dog can sit up there. Personally, I wouldn't use this material for the main cabin or bow. Further, while it looks great, I'd prefer a color that doesn't get so hot. Setting that aside, it's very durable and wears well on the swim deck and transom pass-through. No issues whatsoever. I believe it's 6 mm. A shout out. SeaDek is super responsive, is very good at what they do and deliver a high quality product. If you follow their template process to a tee, spend a few extra bucks for the digitized dry fit, clean the surface properly and lay it down slowly using a suitable roller, it'll look and install perfectly. Pic. will be posted separately (size limit).
