brianb1007 Posted August 4, 2015 Share Posted August 4, 2015 I have spun two hubs now in my prop. (Boat: 2000 Chaparral 245SSi Merc 5.7 EFI Bravo 1)Went to the prop shop again today, they advised me that I had the incorrect prop/pitch on it and that is why I keep spinning the hubs. The prop that was on it when I purchased the boat (two months ago) is/was a Turbo three blade stainless 22 pitch. The prop shop told me based on their book, I should be running at WOT 4800-5000 RPM. With the 22 pitch I am only running 3400. I now have a new 17 pitch four blade aluminum prop (Diameter 14.5) that they recommended (have not installed to test yet). What is everyone thoughts? Suggestion on the pitch/number of blades?Thanks! Quote Link to post Share on other sites
bob and betsy Posted August 5, 2015 Share Posted August 5, 2015 I would expect that 17 to pop you out of the hole for skiing, boarding, etc. a 19 might be a better universal prop size for pulling and for top end.I'd test before buying if an option. Quote Link to post Share on other sites
tolson37 Posted August 5, 2015 Share Posted August 5, 2015 Do some "google" ing - there's some good articles to help you. Here's one. www.boatus.com/boattech/articles/propellers.asp Quote Link to post Share on other sites
Shepherd1 Posted August 5, 2015 Share Posted August 5, 2015 Unless someone has fooled around with the gear ratio on the Bravo 1, it should be a 1.50 gear ratio. A 17" pitch with a 1.50 gear ratio makes a lot of sense to me for that particular hull and powertrain. Given your current prop pitch and RPM, I'm inclined to believe you have the 1.50 gear ratio.As the 245 SSi was really a rebadged 2335 SS, you could expand the search to see what others on the forum or net might be running for props with a MerCruiser 5.7 EFI. Personally find 4 blade ss or aluminum to give the best all around performance on a single prop boat. The 245 SSi of course was only made for a few years.The only real concern I have is how an aluminum prop (even if it is a newer style Spitfire or Nemesis 4 blade aluminum) will perform on your boat due to it's weight and power. If the boat was mine, I'd look at installing a 4 blade ss prop such as the Revolution 4 in a 17" pitch right hand rotation, but the engine has to be able to turn it. IMHO, you'll want closer to 4800 RPM than 4400 RPM at wide open throttle with an average load. At the very least, you'll need to test the 17" prop to see how the boat performs.NOTE: should you ever smash the lower unit off a shoal, and really want to improve the boat up regarding all around performance, than I would install a 2005 and newer style Bravo 3 drive in a 2.20 gear ratio, and install 24" props. The 2005 and later Bravo drives shift a lot smoother and quieter than the older models. Quote Link to post Share on other sites
brick Posted August 5, 2015 Share Posted August 5, 2015 The 17 inch pitch sounds about right. Try it and see. brick Quote Link to post Share on other sites
bob and betsy Posted August 5, 2015 Share Posted August 5, 2015 Unless someone has fooled around with the gear ratio on the Bravo 1, it should be a 1.50 gear ratio. A 17" pitch with a 1.50 gear ratio makes a lot of sense to me for that particular hull and powertrain. Given your current prop pitch and RPM, I'm inclined to believe you have the 1.50 gear ratio. NOTE: should you ever smash the lower unit off a shoal, and really want to improve the boat up regarding all around performance, than I would install a 2005 and newer style Bravo 3 drive in a 2.20 gear ratio, and install 24" props. The 2005 and later Bravo drives shift a lot smoother and quieter than the older models.Shep, I know my Bravo 1 has a 1.33 gear ratio and if he does, it makes even more sense why he's running such low rpms.Also, will that Bravo 3 lower unit bolt right up to the upper unit? That's what I'm kinda hearing but since the shifting is in the upper drive, maybe I'm misreading?Thanks. Quote Link to post Share on other sites
brianb1007 Posted August 9, 2015 Author Share Posted August 9, 2015 Finally installed the new prop and test drove. WOW what a difference. It's a different boat now. Acceleration is incredible and get moving much better with the 17 pitch prop. I did notice that at WOT I was running 4200-4300 rpm, too low? Wonder what my gear ratio is with that being said. Thanks again everyone! Quote Link to post Share on other sites
drewm3i Posted August 9, 2015 Share Posted August 9, 2015 I'm thinking you may need a 17 pitch 3 blade stainless for best all around performance. You should be at 4500-4800rpms. That's a heavy @ss boat! Quote Link to post Share on other sites
