I need suggestion on what chemical to use and the safety factor with fiberglass. Acetone was recommended however, I am a little reluctant to use this chemical. Any and all suggestions would be appreciated.
Thank you. (Tennessee - Tims Ford Lake)
We would need to know the make ,year & model to answer that accurately. Some of us have some very old glass hulls.
Why does a pressure wash job not remove 99% ?
if you are wanting to remove the brown scum line & get your hull back to white - most all products that have "hull cleaner" in the description will use muratic acid or similar. Stay away from pure acetone or other pure acids unless you dilute - those can and will remove paint. The store bought hull cleaners work well to remove the scum line. wear rubber gloves and start with a small area for testing and you can dilute as needed. when you are done hose down everything and then use a polish followed by a wax. the hull cleaners work well on fiberglass and the SS hooks trip tabs but avoid the plastic areas.
Go to your local dollar store and pick up a few bottles of tub and tile cleaner.
$1 a bottle, empty them into a bucket with with some dish washing liquid to thicken it up.
Apply with a little elbow grease to your hull.
Let it sit for a few minutes and hose off... you're done.
We use toilet bowl cleaner (the Works) followed by a good wax job...works great. If you do go the acetone route be sure not to use it on your decals, it eats them up.
I read all the time that hull cleaners are basically acid. An old friend suggested that I use acid to clean my boat one or twice a year and I have been doing it for almost 10 years now on each of my boats. Every cleaning is immediately followed by a rinse, wipe, final wash with soap and then a wax job.
Jug of Muriatic Acid - less than 10 deers - 2-3 cleanings
Yard pressure sprayer - 20 deers or so. If you rinse and flush after use, they last quite a while.
No scrubbing, AT ALL to remove river scum? - priceless.
I originally worried that I was damaging the hull, gelcoat, etc. But after this much time, I haven't witnessed any adverse effects, other than what the acid will do to an aluminum trailer. But that's another story...
Mary Kate ON/OFF hull cleaner. Quick and easy!
+1 That's what I used when I left the boat in the water way too long and it looked like a coral reef had developed on it's bottom. I was so bummed out but after a bit of that stuff (gotta be careful with it) it got rid of everything and brought the shine right back. I was impressed.
and it's so easy. I use a paint roller pan and a boat brush on a pole. Dip the brush, apply to the hull, let sit for a couple minutes, scrub a little and wallah, clean. keeps my hands away from the stuff too.
Old guys have a few acid burns using gloves. Acid gets on everything .especially a trailer or floors. The long handled scrub brush saves skin & all else.
Old post got me. :)
