Newmexicochuck
1996 signature 25 horn and outdrive reservoir
I recently purchased a 1996 sig 25 and am restoring it. The horn does not work and I cannot find it. Suggestions? Also, the outdrive reservoir was leaking. I replaced it, but it immediately went empty (I assume into the drive as there is no sign of it in the bilge) Is it possible that the drive lost fluid when the reservoir leaked?
I checked my owners manual and there is absolutely nothing about the horn in the manual.    I do know there is a fuse that could need replacing but could find anything on where the horn maybe.
You can gain access to the horn through the anchor locker, I would unplug it and use a meter to see if you have power to the horn, most likely your horn is bad.  Replacement horn is AFI Phase II drop-in hidden horn, they have them at West Marine
If you PM me, I will send you a picture of where it is, on the starboard side, 1' back from the bow, should have a white plastic grill over it
