I have twin Mercruiser 4.3 and and all of a sudden the starboard engine is running at higher rpms than the port engine. At full throttle I'm getting about 4800 rpm on the starboard and 4100 on the port engine. I'm curious what would cause this, both engines seem to be running well and I don't feel a lot of pull on the starboard side, in fact my sync gauge shows that the port engine is pulling a little stronger.   Thoughts?
HAVE YOU CHECKED THE LINKAGES AT BOTH ENDS ?  See if any adjustments are not tightened correctly. After that It is checking parts like plugs, rotor cap wire on plugs fully & other parts if not checked earlier.
Do they sound out of sync?  These tachs always act up and I know I've gotten them to read properly by pulling them and working the screw back and forth on the back of the gauge that lets you select 4,6,8 cylinders.
I have not.  I'll check it out this weekend. I'm also going to tune it up.  Thanks for the feedback!
No they sound in sync.  I'll take a look at the gauge.  It would be nice if it were that simple, doubt I'm that lucky.  Thanks
