buzzman Posted July 17, 2016 Share Posted July 17, 2016 Boat won't go over 3000 RPM lose of power and shakes a bit. Could it be the spark plugs. 2006 signature 276 Volvo Penta 8.1 gi-g please help! Thanks Quote Link to post Share on other sites
mightys4 Posted July 18, 2016 Share Posted July 18, 2016 I recently had a similar issue, it was the high pressure fuel pump. They are apparently notorious due to design and paint on the inside of the pump or assembly. Check your fuel pressure. You will likely need plugs as well as it fouls the plugs running such low pressure. Quote Link to post Share on other sites
cyclops2 Posted July 18, 2016 Share Posted July 18, 2016 If you have a distributor cap ? Check it & rotor for cracks, salty crusts, carbon tracks. I find most problems are ignition parts. Except for the STUPIDEST Volvo premeditated destruction of a pump by painting the insides of a fuel system ..........True deliberate destruction of a engine that can die in a storm. When needed most. Recall anyone ? Free of charge ? Quote Link to post Share on other sites
buzzman Posted July 18, 2016 Author Share Posted July 18, 2016 Thank you both. Is it difficult to replace the pump as I see the part online? Can I do it myself? Quote Link to post Share on other sites
Restless Posted July 18, 2016 Share Posted July 18, 2016 Had same problem, once fuel pump is replaced you might as well pull fuel rail and injectors as they will be fouled with paint chips Quote Link to post Share on other sites
buzzman Posted July 18, 2016 Author Share Posted July 18, 2016 thank you all. Did your boats rev at normal RPMs on neutral like mine and not rev over 3000rpm once in gear? Quote Link to post Share on other sites
Restless Posted July 18, 2016 Share Posted July 18, 2016 I have twin engine set up, at idle everything the same, once under way one engine would rev up to 4700 other couldn't get over 3400, soo top speed 28 mph. Fuel pump and injector rail was my problem Quote Link to post Share on other sites
Big Fun Posted July 18, 2016 Share Posted July 18, 2016 Those fuel pumps are costly, have a good mechanic tune it up first and check out the problem. Quote Link to post Share on other sites
