AOSJeff
Tower Speakers
Hello,  I currently have a JL 4/400 powering 4 Polk audio 6 1/2" tower speakers and was going to upgrade to JL audio mx650's to take the polks place. The JL's don't fit the speaker cans to my standards and was wondering if 4 m770's would sound better than 2 m880's? I'm not wanting to change my amp set up but just want to get the best sound for the buck. Any help with experiance would be greatly appreciated.
Also, I will be having 4 Polk Audio 61/2" speakers for sale that only have one season on them and custom tower speaker cans that have red front and back with brushed aluminum cans. Clamps will fit 2.375" or smaller towers.
In theory, no, not better, but certainly louder. In the case of the 880, it may actually be a different outcome regarding SQ. In the 7.7 series, there is an actual T tower model designed for small tower pods. This improves the mid-bass as compared to the same 7.7C in-boat if run in a small pod. However, the 8.8 only comes in a C in-boat version. In a small tower pod, mid-bass is reduced a little, letting the large 1.25" tweeter to become a little dominate. Another thing to consider, is amplifier configuration. 2 pair 7.7's wired 4 chnl stereo would be 75W rms each for a total of 300W tower setup. A single pair of 8.8 you would want to run them bridged with the amp in 2 chnl mode, for 200W rms to each for a total of 400W to the tower. This extra wattage could make up the volume difference between 2 and 4 pods.
Wow! Thanks was_wylie_tunes.
You helped me with an earlier post I made about the in boat speakers.
I can actually get a better deal on the pair of m880's than the 4 770's. About 300 deer cheaper.
I changed the bow speakers to Mx650 because the 7.7 wouldn't fit and the cockpit speakers to m770's. I also added a M10ib5 sub. I'm running m700/5 for the sub and the in boat speakers. The system sounds awesome and well worth the money. The current tower speakers are fine but I want the kids to hear the music load and clear while pulling them and also when we are just hanging out in a cove.
My local JL guy seems to think the quad 770's would be the best route but at the same time the long through 880's I've heard nothing but great things about.
if it were your boat which route would you take?
Thanks again!
Wet Sounds Rev-10 driven by a Wet Sounds Syn-DX4. Other wise, I would suggest 2 pair of the 8.8 and yes, you will need another amp. Swap out the M400/4 or add a 2nd.
Thanks again!
What did you decide to go with?
I have a similar set up with a few more speakers. I have 6, M770’s in the cockpit area with one M10” sub, 2 tower M880’s which are purchased but not yet installed and another 2 M880’s in the stern. The previous owner installed a set of 770’s there previously or I wouldn’t have done that. Not a fan of cutting holes in a boat but they were in so just needed to make the hole a tad bigger. I’m powering the set up with two JL amps. One 700/5 and a 400/4. Looking forward to getting the towers added and completing the system.
Agree with Wylie the Wet Sounds Rev speakers do project better at a distance because the speaker is designed specifically to do that.  If distance at volume is your main priority to be able to get sound out 60+feet great but for my ears, the JL’s sound better.
I went with the Quad m 770’s.
They sound great but the cons are we have to turn down the bass on the boat to make them sound the best.
Are they run on an external amp? They should be set to hi-bass and not get any bass from the source unit.
