TDLucas Posted June 4, 2017 Share Posted June 4, 2017 What is up here? Hooked up the muffs, turned on the water full blast, started the engine and noticed that the water temp gauge started moving too soon. Got out and looked at the muffs, and there was no water coming out of the engine, as there usually is. All of the water was coming out of four holes in the front of the lower outdrive. Of course I immediately turned off the engine. What's up? Impeller? I just got the boat back from the mechanic! Quote Link to post Share on other sites
Shepherd1 Posted June 4, 2017 Share Posted June 4, 2017 Sounds like you have a dual water pick up Bravo drive. There is a cover you can buy for the 4 forward holes, but simply putting some tape over the 4 holes will prevent air from getting into the system, and thus allow the impeller to draw and push water properly when running on muffs. I'm hopeful that you didn't burn out the impeller. Good job on staying alert and responding as you did. Mercury/Quicksilver part # 44357Q2 https://www.walmart.com/ip/Quicksilver-Dual-Water-Pickup-Seal-Kit-fits-44357Q2-Flush-Kit/42030423 Quote Link to post Share on other sites
TDLucas Posted June 4, 2017 Author Share Posted June 4, 2017 35 minutes ago, Shepherd1 said: Sounds like you have a dual water pick up Bravo drive. There is a cover you can buy for the 4 forward holes, but simply putting some tape over the 4 holes will prevent air from getting into the system, and thus allow the impeller to draw and push water properly when running on muffs. I'm hopeful that you didn't burn out the impeller. Good job on staying alert and responding as you did. Mercury/Quicksilver part # 44357Q2 https://www.walmart.com/ip/Quicksilver-Dual-Water-Pickup-Seal-Kit-fits-44357Q2-Flush-Kit/42030423 Thank you! I will tape up the four holes in the morning and let you know if my impeller is still intact. Quote Link to post Share on other sites
TDLucas Posted June 5, 2017 Author Share Posted June 5, 2017 21 hours ago, Shepherd1 said: Sounds like you have a dual water pick up Bravo drive. There is a cover you can buy for the 4 forward holes, but simply putting some tape over the 4 holes will prevent air from getting into the system, and thus allow the impeller to draw and push water properly when running on muffs. I'm hopeful that you didn't burn out the impeller. Good job on staying alert and responding as you did. Mercury/Quicksilver part # 44357Q2 https://www.walmart.com/ip/Quicksilver-Dual-Water-Pickup-Seal-Kit-fits-44357Q2-Flush-Kit/42030423 Impeller is burnt up. It's a brand new lower outdrive and I didn't notice soon enough that water was escaping from the four intake holes. Quote Link to post Share on other sites
Shepherd1 Posted June 5, 2017 Share Posted June 5, 2017 Replace with Mercury part # 46-807151a14. Try and find all the old impeller bits; quite possible they're in the engine oil cooler and power steering cooler. Quote Link to post Share on other sites
