BRUCE J BEEGAL
alarm system
On 6/13/2017 at 2:53 PM, BRUCE J BEEGAL said:
Need help with an alarm going off 2 beeps when turning the key and stays on.
Two beeps indicate a non-critical alarm and if it's a Merc, there are several possibilities which can be hard to narrow down without a scan tool. Likely sensor related and if you provide year, horsepower, and brand of your power package we may be able to provide some insight. If it's a late 2000 vintage or newer, your Smart Craft display will give you a read-out pointing you in the right direction. The buzzer Southern Cross is looking for hangs in the wiring harness under the helm and looks like a 1" diameter hockey puck. That said, I ask why he would care where it is unless he is looking to disconnect it. Real bad idea as it's trying to tell you something, Don't take the battery out of your smoke detector until you are sure your house is not ablaze. Ha...   Below is a list of alarm possibilities, and you should focus on the ones that say "Two Beeps per Minute".   W
Warning System
The engine warning system incorporates an audio alarm and, if installed, a SC1000 System Monitor. When the key switch is turned to the ON position, the audio alarm will momentarily activate to test the warning system. The alarm should sound once if the system is operable. This table is a guick guide, showing what warning output will accompany a fault.
Fault
SC1000
Audio Alarm
Available Power
Cam Sensor
Yes
2 Bp/min
90%
Open or short, engine must be cranking to set this fault code.
ECT CKT HI
Yes
2 Bp/min
90%
Open
ECT CKT LO
Yes
2 Bp/min
90%
Short
ECT Coolant Overheat
Yes
Constant
6-100 %
Engine guardian overheat condition
EST 1-8 Open
Yes
2 Bp/min
NA
Coil harness wire open
EST 1-8 Short
Yes
2 Bp/min
NA
Coil harness wire short
Fuel Injector 1-8 Open
Yes
2 Bp/min
NA
Fuel injector wire open
Fuel Injector 1-8 Short
Yes
2 Bp/min
NA
Fuel injector wire short
IAC Output
Yes
2 Bp/min
90%
Only with rpm
Knock Sensor 1
Yes
2 Bp/min
90%
Alarm sounds for 20 seconds in NEUTRAL and indefinitely in gear.
Knock Sensor 2
Yes
2 Bp/min
90%
Low Drive Lube Strategy
Yes
Steady Bp
0-100%
Low oil in sterndrive
Low Oil Pressure Strategy
Yes
Constant
0-100%
Low oil pressure strategy
MAP Sensor 1 Input High
No
2 Bp/min
90%
Short, no visual on SC1000
MAP Sensor 1 Input Low
No
2 Bp/min
90%
Open, no visual on SC1000
MAT Sensor
Yes
2 Bp/min
90%
Open or short in MAT circuit
NOTE: If any 5v sensor becomes shorted to ground the engine will not start. If the engine is operating when the short occurs the engine may stop operating and will not start.
Fault
SC1000
Audio Alarm
Available Power
Oil PSI CKT Hi
Yes
2 Bp/min
90%
Short, defaults to 51.7 psi
Oil PSI CKT Lo
Yes
2 Bp/min
90%
Open, zero oil pressure
Overspeed
Yes
Constant
RPM Limit
Engine over rpm limit
Port EMCT CKT Hi
Yes
2 Bp/min
90%
Open, defaults to 32 degrees F (0 degree C)
Port EMCT CKT Lo
Yes
2 Bp/min
90%
Short, defaults to 32 degrees F (0 degree C)
Port EMCT CKT
Overheat
Yes
Constant
6-100%
Overheat condition, 212 degrees F (100 degrees C) limit
Sea Pump PSI Lo
Yes
Constant
6-100%
Low water pressure strategy, defaults to
43.4 psi
Sea Pump CKT Hi
Yes
2 Bp/min
90%
Open
Sea Pump CKT Lo
Yes
2 Bp/min
90%
Short
STB EMCT CKT Hi
Yes
2 Bp/min
90%
Open, defaults to 32 degrees F (0 degrees C)
STB EMCT CKT Lo
Yes
2 Bp/min
90%
Short, defaults to 32 degrees F (0 degrees C)
STB EMCT CKT
Overheat
Yes
Constant
6-100%
Overheat condition, 212 degrees (100 degrees C) limit
Steer CKT Hi
Yes
No
No
Open and short
TPS1 CKT Hi
Yes
2 Bp/min
90%
Short, signal to 5v+, engine will not start. Refer to data monitor screen.
TPS1 CKT Lo
Yes
2 Bp/min
90%
Open
TPS 1 Range Hi
Yes
2 Bp/min
90%
Above 4.8v, 994 counts
TPS 1 Range Lo
Yes
2 Bp/min
90%
Below 0.5v, 35 counts
Trim CKT Hi
Yes
No
No
Short, high range, visual warning on SC1000 only.
Trim CKT Lo
Yes
No
No
Open, low range, visual warning on SC1000 only.
5 VDC PWR Low
Yes
2 Bp/min
varies
Short any 5v+ to ground
