TDLucas Posted June 27, 2017 Share Posted June 27, 2017 A potential buyer hand-spun my duo propeller and said it was in bad shape. He could hear the gears turning and could feel the gears turn in the propeller blades. I just got the new lower outdrive back from my mechanic, and I thought the noise was normal. Should I take it back to my mechanic? Does yours make noise? Quote Link to post Share on other sites
Ingalp01 Posted June 27, 2017 Share Posted June 27, 2017 Good question? I've never "hand spun" my duo props on the B3... Other than some mysterious vanishing drive lubricant, mine seems in great shape, 545 hours. I'll hand spin it when I get home tonight and see if it makes any noise... Quote Link to post Share on other sites
Mi3sons Posted June 27, 2017 Share Posted June 27, 2017 Bravo 3 drives feel knotchy when turned by hand and is normal. unless there is some major malfunction. Quote Link to post Share on other sites
brick Posted June 27, 2017 Share Posted June 27, 2017 On my B3 drive you can "feel" the gears turning, when turned by hand. But it does not feel bad. brick Quote Link to post Share on other sites
soldier4402 Posted June 27, 2017 Share Posted June 27, 2017 every time I have turned a drive by hand I could either feel or hear something turning a little. Guess without being there its hard to say. Quote Link to post Share on other sites
dn0349 Posted June 27, 2017 Share Posted June 27, 2017 You'll feel the gears but it should be pretty smooth Quote Link to post Share on other sites
cyclops2 Posted June 27, 2017 Share Posted June 27, 2017 He is a smart buyer trying to get the price down ? Quote Link to post Share on other sites
TDLucas Posted June 27, 2017 Author Share Posted June 27, 2017 4 hours ago, cyclops2 said: He is a smart buyer trying to get the price down ? That could well be! Quote Link to post Share on other sites
Bt Doctur Posted June 27, 2017 Share Posted June 27, 2017 properly shimmed and assembled I have never "felt" the gears mesh. If you can feel them and its clunky something is wrong turning the prop turns the pinion and lower gear set ,also turning at the same time are the F and R gears in the upper. They should not feel binding or rough http://www.boatfix.com/merc/Servmanl/11/11covr5x.pdf Quote Link to post Share on other sites
