randy569 Posted July 2, 2017 Share Posted July 2, 2017 my son put in a new battery but hooked it up backwards, it smoked the alternator but I re did the connections ,now motor cracks, all elec works but the alarm stays on when I turn the key, and fuel pump doesn't kick on and no spark Quote Link to post Share on other sites
randy569 Posted July 2, 2017 Author Share Posted July 2, 2017 oh its an 05 ssi 210 Volvo penta Quote Link to post Share on other sites
cyclops2 Posted July 2, 2017 Share Posted July 2, 2017 Last chance. Did you reset all breakers ? Even if they looked O K ? PUSH & RESET them. If there are any fuses. ONLY remove them 1 AT A TIME. & test each by itself. You might get lucky. Check fuses & breakers on the engine. Quote Link to post Share on other sites
randy569 Posted July 2, 2017 Author Share Posted July 2, 2017 yes I reset all the ones under each and the two by the battery switch, is there a reset button on the engine somewhere like on the mere? I've been looking but can't seem to find ones checked the fuses on the intake they were all ok Quote Link to post Share on other sites
randy569 Posted July 2, 2017 Author Share Posted July 2, 2017 the alternator got cooked not sure if its shorted inside but the case melted Quote Link to post Share on other sites
cyclops2 Posted July 2, 2017 Share Posted July 2, 2017 Need Shepherd 1 & Wingnut............. Do not like the loss of ignition. CAREFULLY WITHOUT forcing or breaking screws holding the distributor cover down.....Remove the cover to check the parts inside for burnt look or odor. Is the battery fully charged up now ? at least 12 .5 volt resting. 12 .2 cranking speed ? Quote Link to post Share on other sites
randy569 Posted July 3, 2017 Author Share Posted July 3, 2017 battery is at 13.4vdc Quote Link to post Share on other sites
cyclops2 Posted July 3, 2017 Share Posted July 3, 2017 What does it drop to while cranking ? Do you have a volt meter you can hold on the battery posts. The 13. 4 is a dash gauge volt meter ? That voltage is way to high or a bad meter. 12. 6 to about 12. 9 maximum is more normal for Lead acid. Quote Link to post Share on other sites
gjt Posted July 3, 2017 Share Posted July 3, 2017 Check main power relay it may be smoked. That powers up PCM and then turns on fuel pump relay. Hopefully didn't fry PCM Quote Link to post Share on other sites
cyclops2 Posted July 3, 2017 Share Posted July 3, 2017 I surfed your reversed hookup. Good news . Some had almost no damage. So maybe doing gjt checkout will get you going. Most lost the alternators. Quote Link to post Share on other sites
