Engine Crankshaft Position Sensor
On ‎7‎/‎3‎/‎2017 at 9:21 AM, Shepherd1 said:
What engine exactly? 496 crank position sensor is mounted at the rear of the engine near where a distributor would sit on an older 454, etc.
I have Volvo penta 5.0 gxi-b
it starts then shut down in 2 to 3 sec
On ‎7‎/‎3‎/‎2017 at 9:24 AM, paulswagelock said:
Yes. Replaced on 496 - relatively easy.
I have a Volvo penta 5.0 gxi-b
I can start the engine after 2 to 3 sec it cut off going crazy
Edited by BRUCE J BEEGAL
up date info
Hmmm, I don't know a 3.5L Volvo, but if the engine was say a Volvo 5.0 GXi-B, I would say it's from the early 2000's.
If you do have a 5.0 GXi-B, then item # 8 in the link below.
https://www.marinepartseurope.com/en/volvo-penta-explodedview-7744230-28-5042.aspx
Pick your poison from the link below:
https://www.marinepartseurope.com/en/volvo-penta-schematics-MarineGasolineEngines.aspx
I'm not familiar with Volvo audio alarm horn strategies, so can't advise you on what you should hear at key on. A crankshaft sensor is certainly a critical component, but I've only ever seen one fail on a 496. (intermittent shut down, and stumbling - would usually restart like nothing was wrong)
Shepherd1 thank you my engine is a 5.0 gxi-b  I am trying to fine a crankshaft sensor. We are checking all the warring and connection on all of the sensor and checking the neutral  safety switch. thanks if you can give me a call 215-768-4100
Can't promise that I'll be able to call, but I'd be very interested to see what your fuel pressure is.
NOTE: care needs to be taken when checking fuel pressure. I don't know the specs for a Volvo 5.0 GXi-B, but would think 43 psi max.
Another thing to try is running the engine off an outboard tank to eliminate a possible problem from the boats fuel tank, fuel line, anti-siphon valve, etc. If the boat does run properly off a shop tank, 6 gallons won't take you very far...
