BRUCE J BEEGAL
Starts and then shuts down
I have a 2003 chaparral 240 signature Volvo penta 5.0 gxi-b (300 hours) I start the engine and it shut down in 2 to 3 sec I can force a start with the throttle and get it to run at 1600 rpm as soon as I touch the throttle it cut off. This is what I done so far checked the fuel ok changed the fuel filter and clean the screen changed the throttle sensor changed all the sensor in the cpu changed the oil sensor checked the fuel lines for pressure hi 60 lbs and low 4-6 and holds also changed the distributor cap and rotor and cleaned the sensor under the rotor. going to try the crankshaft position sensor???? If any one out there could help me I will take all advice..... Thank you.....
