Luigi
Power steering not working
27 posts in this topic
Chaparral 204 2008 4.3 Gxi Volvo penta
power steering stopped working suddenly. I changed the serpentine belt, changed out the fluid with Volvo trim/power steering fluid.
What else should I look at?
I tried turning wheel lock to lock with engine off and on. No change.
Any imput would be helpful, I was told that these pumps last forever
it does work intermittently, weird
thank you
10 years old ?  Check for voltage RIGHT ON the pump motor terminals.  Could be the motor brushes are worn out.  Are they replaceable ? Does it ave a cap your fingers can twist counter clockwise to inspect the brushes ?
Didn’t know there was electric connected to the pump and I thought only powered by the serpentine belt.
  Was thinking power trim motor.  Sorry.
Power off. Can you push the drive left or right with a lot of effort ?  Have you found the pump oil gone & refilled ?
When I push it I would say it’s medium to little effort.
When engine running and it being off nothing changes on effort to turn wheel. I did flush the oil. Not sure if I maybe need to bleed the system. I searched around and saw that simple turning lock to lock would do the job. What should I check next?
The belt driven pump is a positive displacement rotary vane design, and if the engine is running, the oil is in circulation to and from the steering ram, but is doing so at minimal pressure as there is no resistance to it's flow. When steering input is applied at the wheel, a diverter valve in the end of the ram moves a spool and diverts the flow to one end of the ram's internal piston or the other, while the exhausted oil from the other end of the ram is displaced back to the pump suction. This slip stream varies in volume depending upon how fast the steering wheel is being turned. When wheel movement stops, the spool returns to it's home position, and all of the pump's delivery is in simple low pressure circulation and is returned to the pump suction line. This all works sweet, until an operator turns the wheel all the way to either port or starboard. The diverter is telling the pump that it needs full flow to the ram, but the ram is at the end of it's limit of travel and pressure builds to excessive levels. At this point, an internal pressure relief valve opens and dumps the excess pressure back to the low pressure side preventing system damage. Some of these pressure relief valves are pump mounted but most are an integral part of the ram. In your case, either the diverter valve is sticking, or your safety valve hangs open on occasion. It would seem that the pump is working fine as you stated that the assist works on occasion. The bad news is that on the newer Volvo's the ram is serviced as an assembly, but you can tell if that is the case on yours by seeing if it is a sealed unit, or if the diverter valve is bolted on to the end of the ram assembly.  Good luck.   W
Do you know why when I sometimes start the boat out of the water, the steering wheel turns by itself all the way to starboard side (Quick movement)  Doesn’t do that all the time. Sign that the pump is actually working?
That is an indication that the spool valve is not finding it's null bias when at rest. Two counter-opposing springs are intended to auto center the valve, and keeping the oil flow in full by-pass back to the pump. Time to service the diverter.  W
Do you have a diagram of where the diverter valve is located? All I can find is the steering ram with piston etc... sorry for my ignorance as the power steering is my weakness area. Could this be a DIY? It’s hard to get a Mechanic out here in Miami since this is considered to be a small job and most wont take it
Thank you.
the last time I investigated that system I could not find a spool valve to adjust, just steering cylinder replacement. There is not even a diagram of the internals or how to disassemble it
For the cost I would just go with a hyd ststen and say the #$^% with overpriced volvo or adapt a Mercruiser cylinder in its place.
Thank you.
The divert is integral to the steering ram, situated at the hose entry points. As you cannot see a bolt on unit, it sounds like you have the newer, non-serviceable unit that gets changed out as am assembly. A picture of the ram with attention to the hose entry end would help.   W
Will do. I’ll take the picture tomorrow. Thanks again for the help.
2 hours ago, Luigi said:
99% sure that it does look like that one.
Yea, that unit is serviced as an assembly. 500 retail, 400 e-bay. Sorry.  W
Won’t that rebuild kit you posted earlier work?
No, that kit only addresses a failed cylinder piston seal, and has no association with the control valve that sends fluid to and from it. Sorry.  W
Id like to report back on this issue i was having so it can help any other members on this forum. I decided to get the rebuild kit and it worked. The o ring on the piston was worn and was missing the piston seal that goes over the o ring. the new kit came with the same o ring it had (slightly smaller) with an additional piston seal that goes over the o ring. if anyone needs the info where i purchased the kit let PM me. I'm not sure if I'm supposed to put sites on here.
for future members looking at this, before you purchase the rebuild kit, this kit fixes leaks in the actuator and power steering loss due to the piston seal being worn, broken or missing.
if your piston is cracked you might be able to fix it with some epoxy. the kit cost $60 and far better than having to buy a new actuator ram for $600 or used one for $300!
I can finally put my incredible Hulk arms away and turn my steering wheel without effort!
Go ahead and post it.  That will be useful to someone else down the road.  Links are posted here all the time.  I can't see Chaparral having an issue with this one.  Even if they did, the moderators usually just quietly delete things that aren't allowed.
