ChrisB
New to us 2002 Chapparel 260 SSI
3 posts in this topic
Just purchased a 2002 Chapparel 260 SSi last weekend. Upgraded from our first boat which was a 2000 Crownline 180. We weren't looking for a boat this big but it is a sweet boat and only has 340 hours on the Vovlo 5.7 Gxi. The 5.7 is probably a little underpowered for this large a boat but we don't do any watersports except for some occasional tubbing and the lake we go to, Lewis and Clark in Yankton SD, isn't t that big. So far I have been impressed with the quality of the Chapparel in comparison to the other boats we looked at. The only issue I see with this is the Vovlo power plant. There aren't a lot of places around here that work on them but then again I like to do all of my own maintenance. I've heard that Vovlo's are easier to work on but the parts are a bit more expensive. Oh well I like the challenge of learning something new.
I belong to the Crownline HQ forum and when I bought the Chapparel I went looking for their forum. There appears to be a lot of good information and a lot of knowledgable people on here!!
Nice boat choice.
Service availability and parts cost are the typical complaint you hear about Volvo. And the dreaded XDP drive...
Love that hull and layout; great boat and upgrade from your old 180 Crownline. Do you have the optional extended swim platform? Adding Seadek adds a lot of comfort and grip, and does not get hot on the feet. Hard to believe no one out there has asked for Seadek to make a kit for a 260 SSi bow rider or 265 SSi cuddy in the past, but I don't see a kit listed. I know the extended portion is the same as the 235 and 246 SSi, etc.
http://www.seadek.com/c-21-chaparral.aspx?pagenum=1
Image result for chaparral 260 ssi
Regarding the Volvo, recommend doing a tune up. Can use MerCruiser parts if wanted for the cap, rotor, and spark plugs. (GM HVS style distributor is prone to fouling from humidity, etc)
NOTE: Volvo HVS style distributor cap uses aluminum terminals instead of more expensive and longer lasting brass type that MerCruiser uses. Volvo spark plugs are also sourced from Champion; I personally prefer the latest NGK ITR4A-15 Laser Iridium - Merc says they're supposed to last 400 hours.
Cap and rotor - Mercury / Quicksilver part # 8M0061335   -   NGK ITR4A-15  (pre-gapped to 0.060" - DON'T touch or adjust the gap or you'll break the electrode off)  Can probably get the spark plugs  and distributor cap and rotor at a local NAPA - 1997 Chevrolet 1500 with 350 V8.
Following link will take you to Volvo marine parts look up; this site is actually run by Volvo Penta. Guessing you have a 5.7 GXi-B model with a DP-SM drive.
https://www.marinepartseurope.com/en/default.aspx
Lastly, if the serpentine belt is making a lot of noise, recommend pulling off and replacing with a Continental Elite version. Auto supply store will need the old belt to match up.
Have fun with the boat!
Image result for continental elite serpentine belt
