rbe1018
AC help
I have a 2012 310 and have a problem I need help sorting out. I am constantly getting an HPF code. Thought we were to close to bunks on lift and it was cutting off water flow but that's not the problem. Coil is clean, it had a mesh prefilter that was very dirty as well as return air grill was a bit dirty too. Cleaned them and still have issue. Sometimes it happens quickly then others it works right for a couple of hours. Sometimes it HPF's when the unit cycles off and tries to come back on. What do I check next?
Check the strainer? Maybe the pump is bad or sucking air due to a loose connection. Could be an obstruction between the pump and overboard discharge. I had a dirt dauber just inside my overboard discharge once. I used a garden hose with the spray nozzle and backwashed the system and it cleared it up.
