Sakison
Out Drive Chatter
Just recently I have noticed a chatter coming from under the swim platform when the boat is in neutral and idling.
The outdrive seems to operate normally under speed.  I am wondering if maybe the linkage is out of adjustment
and the outdrive is not 100% disengaged,  The prop is not rotating while the boat is in neutral.
Could be a coupler or gimbel bearing going bad as well. Can you hear the same chatter when you stick your head in the engine compartment?
Which outdrive do you have?
Well from experience.....check it out throughly.  Was on lake 2 weekends ago going to blue angels show and the outdrive burped up a bunch of drive fluid back up thru the lube bottle ( blew the cap off ) and the upper gears are gone. Slivers of metal throughout drive.  Gonna need a complete replacement.  No noises, no warning, lube was full (checked at upper plug and bottle prior to going out). A loud grinding noise followed by deceleration and engine stalling.  2.5 BOATs later I will have a new replacement drive.
Must have it checked !!  Before any more running.
I had the exhaust flappers clicking in neutral with a definite ticking metal on metal  sound. It disappeared above a normal idle speed. Sounded like a car lifter or sticking valve.
I too had this happen on a 3 year old set flappers.  Almost sounded like a rod knock,  took the flappers out of the port side and noise gone, put back in, noise returned.  Flappers seem just fine.
Not to be trivial but I had a similar issue and found out it was the door covering the swim ladder on the swim platform. Again not trying to be funny just a thought.
This is Why I continually post & harass the daylights out of some perfect people.  Be hopeful that it is something to laugh about at a enjoyable dinner.
Edit
Always post  .....WHAT......was the real problem & how it was solved.
Some are real pains. Like original factory bolts that were too long or never coated with water proof sealant.
I thought I had an issues once as well and determined it was the cockpit door chattering.
