Bo B.
winterizing
I have a single point drain system on my 4.3 L Mercruiser.  Do I need to add antifreeze after draining the system?
Personally I would remove that system because if you depend on a visual draining not knowing how much should come out ,you should see close to 4 gallons of liquid. At the very least remove the quick connect hoses at the block and probe the opening to ensure draining. If the block drains are clogged you cannot drain the water from the engine block and that will result in a engine  replacement in the spring
