Bt Doctur
Volvo to Mercruiser raw water pump conversion
4 posts in this topic
Just completed a conversion  and all went well. the crank mounted pumps just kept spring water leaks at the seals.
pics and instructions included
  Finally Complete, all spacers will be machined from 3/4 round stock , 1 inch hose couplings/joiners/ splice .(3) , 6 hose clamps,
Dayco hose 71596 , original thermostat hose to pump is reversed and given a slight twist to join. From the original raw water inlet hose at the pump cut off the 1 1/4 end so its 3 inches long and save, (pic 1)cut off the 90 deg bend and discard, shorten the raw water inlet hose at #6 spark plug by removing 8 1/4 inches, and use hose splice to join and clamp.Install and clamp Dayco hose , install original thermostat hose reversed and join to Dayco hose with joiner/splice and clamp. Not shown is a ty-wrap holding the Dayco hose in place.,5th pic.
raw water pump pully alum 52822T, steel 73798A1, engine mounted pully 90081T1, pump bracket 89535T
all figured out except to the raw water to the T housing..Final length of the spacers is 1 3/4 to be machined from round stock. lower adjusting bracket for the PS was lengthened 1-1/6 with plates welded on both sides. Actual length was 1 /1/8 but left is short a bit. Easier to add 2 washers than to cthe welds and shorten it.Short water circ pump bolt removed and a 3 1/2 inch bolt installed. Belt alignment is perfect and a 37.5 inch belt used with good adjustment range
Some preliminary pics
