milton.irizarry
Gas odor inside cabin
6 posts in this topic
I have a 2002 Signature 280 my cabin smells like gasoline when I open the boat or run the AC . Does anybody have this problem and what could it be
If it smells in the cabin and not the engine compartment you have a tank leak. Either hoses or sender or tank itself
Yep, get it to the shop......
You have a gas leak. I am sure you know this is a very dangerous and serious situation.
Four things to consider, check, and exclude one by one, carefully ...
1. Gas spilled during fillip went into bilge
2. Leaking hoses: fill up, vent, engine pickup, genset pickup
3. Seal around fuel level sensor/sender leaking
These woud be easy to fix, if non of them then ...
4. Leaking fuel tank ... get a professional help.
Could be leaking tank, loose sender gasket, fuel filter spill from a change, old fuel lines that have had the lining eaten through, or any combination of these. Get an expert to take a look and don't run the boat in the meantime. Also turn off all electrical.
