Amar Nanduri
Thoughts on a windlass anchor
I have heard that it is not recommended to get a windlass automatic anchor for a Signature for a boat frequently used in the Chesapeake bay or in areas having 2-3 foot waves. The argument against it is that due to the constant movement of the bow the anchor might smash into the boat and damage the hull, compared to a manual anchor that resides in the anchor locker.  Is this true ?
Me and my wife are debating on whether we should get an automatic anchor for the signature or stick to a manual one
Best
Amar
I would say no. I boat in the Boston area and for me, hitting 2 to 3 foorters happens 3 to 4 time a year if not more. Never had a problem with the anchor. First off, your anchor should be snug against the bow roller. So there sould be no movement.  Thats were I would keep it windless or not. It make for easy use and if something happen (engine quits or...) I want to be able to deploy it quickly. If your in rough seas, do you really want to be pulling your anchor out of the locker. Not me!
Also, keep in mind that if you use a windless. There should be a safety cable attached to the anchor so it can not deploy on its own.
I added a windlass to my boat this past Spring and love it.  Makes anchoring so much easier.  We boat in the upper Chesapeake Bay and had to no issues with the anchor hitting the hull.  We don't go out in 3+ foot waves but the windlass lowers it quickly so I doubt you'll have problems.
3 hours ago, Ed said:
go for the windless, your never regret it.
Yep!
I have a electric powered anchor on the bow of the 16' Lowe fishing boat. 3 styles of anchors for different bottoms . A  S S  threaded link allows a  18" X 2" solid rod with a screw eye to be used in mud or weeds every few minutes when fishing. Change over to a Mushroom or a 20" wide Fluke Anchor for high winds & waves. Change over time is 2 to 3 minutes at most.
Powered anchors are a must in nasty weather. I have a VERY heavy chain length of chain that can be added to the anchors with more threaded links.  If nasty anchor dragging conditions come up. The 16' boat has a hand crank up stern Mushroom Anchor also.  I have stern anchors for all boats.
A word about anchor lines in VIOLENT waves.  ONLY BUY A STRETCHY anchor line. DO NOT make it to big in diameter to be.... EXTRA STRONG.... That removes the highly desirable stretch needed.  There were charts posted on a boating web site giving additional pounds of pressure on the line.  As WIND SPEED PICKS UP & pushes on above deck areas.
There are those black rubber line devices to reduce the peak shocks of waves.  I have no idea if they really do reduce the shocks so much. None ov my boats have or nned them with 200' to 300' lines out. Plenty of stretch.
30 minutes ago, Boater71 said:
can I add a windlass anchor to sig 270?
You can add a windless to almost any boat. The real question is, would you need a vertical or horizontal one based on your boat.
On ‎1‎/‎14‎/‎2018 at 12:21 PM, Amar Nanduri said:
Thank you cyclops2 . I will definitely keep your recommendations in mind when I purchase my next anchor and windlass.
Are you from India?
I know this thread is from last December, but, keep us posted if and when you decide to do it.  I've bought all the parts to add a windlass, from the SS anchor to the specific bow roller which is designed for the 277 ssx and I just had the flange spread a bit wider 3/8th" to accommodate the shape of my 276 bow and have all the necessary accessories and electrical components to do the entire project this fall.  I have a bow ladder that I don't want to lose so my installation is going to be a lot trickier than if I just remove the bow ladder and permanently close its hatch and just have the windlass anchor.  I have just enough room to house the windlass anchor so that it slides under the ladder and still be able to use it.  Should be a fun project and actually can't wait to get started.  Toughest part will be getting up the nerve to cut a 2-1/2" X 3-1/2" square right in the front top of the bow about a foot and a half above the bow eye!  But we're doing it because just like it's a pain in the a$$ pulling out fenders every time you dock, the same headache it is with a regular anchor.  Let us know how you make out.
Powered anchors are a joy.
At 80 years old I did a synchronized bow & stern anchor setup.  It controls 2 heavy lead window sash weights. They are virtually weedless in all weeds. I had to add some S S small pulleys along 1 side of the boat to have both wound on the same line drum.  It allows anchoring so that the sun is always at our backs when fishing.  Key fob for the winch is nice.
It is on the 16 foot Aluminum fishing boat. But you could do 1 full sized bow winch & I reduced stern sized winch. A little boat shift position to keep the sun on a side of the boat is nice. It could also be used to prevent side to side swinging in a wind condition.
Seriously?  You use old window sash weights as both bow and stern anchors for the aluminum boat?  They're actually heavy enough to hold the boat in position?
You're talking about these, right?
I think they weight about 1-1/2lbs each so you'd probably need at least 4 of them to get enough weight to hold that boat in place.
Back in the day, we filled a 3 lb coffee can with cement, stuck an eye bolt in it, got some cloths line, and were good to go.
Man those were the days! Of course, that was all we had, living on the poor side of the tracks.  Denny.
Call the EPA  !!   :haha-7383:
I use pieces of S S  2" diameter drtive shafts  as calm weather weedless anchors.  Works fine.
On 7/16/2018 at 9:03 AM, Hatem said:
Are you from India?
Hi Yes. I am originally from India and currently reside in northern Virginia. I have decided not to put in a windlass for now as we have not yet done any overnighting on the bay and me and my wife are comfortable with anchoring the boat manually. I might change my mind next year when I plan to get more serious on weekend overnight boating.
Cheers
amar
