Forcruzen
Volvo Duo Prop issue
Rotating the prop by hand it hits in one spot.  Checked the shaft last summer and it seemed fine.  Is there a recommended place to have the props balanced or checked?
9 hours ago, Forcruzen said:
Its a prop to prop issue.  I can see the contact point. Ill email prop md.  Thanks Richard
Well, it almost goes with out saying. You hit something and bent the props.
I vote for a dial indicator reading at the end of the shaft.  Might get lucky.
Props should be bent to bend the shaft. So a check & straightening of the props is in order.
Sounds like you might have hit something last summer.
OPTION 1;You can take your props to your local dealer to have them sent to a prop shop.
OPTION 2 you could just find a prop shop yourself.
