Curt
Question - Trailer
7 posts in this topic
We just purchased a 2016 Chaparral 307 SSX.  Looking to purchase a trailer.  Does anyone know the measurement from the bow-eye to the drain-plug?  Thank you.
It seems Chaparral has decided to stop making available details such as this for newer boats, preferring you deal with your local dealers for information action such as this.  Unless a current 307 owner can measure it for you.
Are you looking for a new or used trailer?  For new, most decent trailer manufacturers will have access to this information and set the trailer up for you.
For used, you need to find a good adjustable trailer and just have your dealer or a trailer service shop adjust it for you to specs they will be able to get from Chaparral.   Base buying the trailer on overall length, weight capacity and condition, especially condition!
Unless you can find a used trailer that was set up for a 307 to begin with, which I think would be hard to find.
It too me a year to find a good, used trailer that was not salt ruined or worse.  It became a mission to find one :)  in hindsight, I should have bought a new one and saved countless hours of searching, looking, being disappointed, etc.
my 255 measures about 22 feet.  Its LOA is 26.5 feet.   so im guessing yours would be 26.
But whatever trailer you get, is gonna have to hold that weight. dry weight is 8400, add options, gas, water.  you will probably need a trailer that holds 10k
Thank you.  The dealer confirmed 29 +/- a bit.  I bought a new tri-axle Venture VATB 12625 Friday.  The winch/bow stop is adjustable between 27 and 30 feet, so the transom will be on the bunks and not overhand.  Preferred the VATB 10625 overall length, but the transom will overhang and I'm not a fan of that.  Two disappointments:  (a) Really like the Loadmaster given fit and their responsiveness, but lead-time was greater than my available time, (b) rims, hubs, bearings and radial tires are all Chinese.  After the initial relocation, I'll probably change bearings to Timken (U.S.A.) and tires to Goodyear Endurance (U.S.A).  Once relocated, the trailer will only be used twice per year - to launch in the Spring and remove in the Fall.  This is our second Chaparral (264 Sunesta with Arch), and third boat (205 Sea Ray).  In our opinion, the quality of Chaparral open bows is far better than the others.  Looking forward to a great Summer.
I have the VATB-7225,  My boat doesn't overhang at all.  My previous boat did, a little.  I bought my trailer in 2015.  i have eco-trail tires, i think they are made in USA, according to google, but not sure.   No problems with my bearings so far, they get a little warm but not hot.  I only use the trailer twice a year, spring launch ...fall  haul out.   The solenoid for the surge brakes went bad, so i had no brakes for a while.  But vantage sent me a replacement.
You live a beautiful part of the country.
A long time back I lived in Rochester.  Love the Finger Lakes, Thousand Islands and Adirondack regions.
Please recall, the trailer question and the Venture VATB-12625 I bought is for a 307 SSX (2016).  Our first Chaparral is the 264 Sunesta (2009) that I mentioned.  The Sunesta doesn't have a trailer.  It was delivered on the lake we reside on, by the Chaparral dealer located on the lake.  Winter storage this year was on a yard trailer, while previous years was in a rack.  Thank you again.
Closing this thread out.
From the bow eye to the drain plug is 28 feet.  If the winch roller is set to 28 feet on the Venture VATB-12625 trailer, the transom (drain plug) sits 6-inches in from the end of the main bunks.  In this position, the boat's weight is evenly distributed over the three axles and the transom is fully supported (doesn't overhang).  The trailer I purchased included electric/hydraulic brakes instead of surge.  I highly recommend this option given all of the weight.  While it added about $600 to the trailer's price, the trailer is much safer to operate and very stable even in heavy traffic.  $600 compared to safety is priceless; to the value of the boat, about one tank of fuel - miniscule.
The 29 foot dimension the dealer referenced is incorrect.  FYI  I too called Chaparral with no response.  This dimension should not be secret on any boat.
To help any future owner of a 307 SSX, if you prefer a Road King trailer, the model number is RKAV 26-28TRB3 10700 LB Net.  A reference VIN is 5KZVBB2838JA053120.  With this information, Road King can build a trailer to the exact dimensions of the 307 SSX.  Please note though, your transom will overhang the bunks and the bunks are approximately 18 inches longer than the rear most supporting cross member.
Happy boating.
