Gapple12
Correct Chaparral gel coat color
9 posts in this topic
I have some missing gel coat or paint on the bottom of my boat from previous owner running the boat up on a beach. Its a small area but I want to paint it. Had a buddy tell me to use a gel coat kit, but when I look to purchase the white color patch kit, there are a few different white colors to choose. Any way to figure out what white I have ? Its a 2006 Chaparral 246 SSI Red and white. Pic attached.
1 hour ago, Mi3sons said:
I believe its mission white.
Yes, when I type in Chaparral/white on iboats.com under boat gel coat, that is what I get. But, I get 3 different kit part numbers for 2000-2015 mission white color boat gel coat. There is also a revolution mission white color.
https://www.iboats.com/shop/paint-and-maintenance/fiberglass-and-epoxy-boat-repair/boat-gel-coat-repair.html?find=chaparral-white-10538997&finder=26
Being on the bottom of the boat at least it doesn't have to be an exact match as it will generally not be seen.
I see only one color for your year: Mission White.
Revolution White is for model year 2015 as it states in your link.
Your right, I missed the year part. I ordered the mission white. Even if its off some, no one will ever see it.
I attempted a gelcoat repair last Fall on my swim platform.  I purchased, I believe it was the Spectrum Color paste kit.  It was actually a lot easier than I expected.  The only problem I had and I couldn't solve was air pockets in the repair area.  But it hardens quickly and once you sand it it shines right up to a perfect color match.
yes you gel coat a boat not paint.  typically most kits you buy have white in it but also either a yellow or tan.  They also provide a color chip so you can add the right amount of coloring.  IN reality as long as its a small spot youll never see it specially if its on the bottom.
