What are people using for deck brushes?
Looking for something to clean foot prints and such that don't just spray off the platform (we don't have a pad on it, just the stock gelcoat). Saw a shurhold blue with "extra soft" nylon bristles. Wondering if that's too soft? There's also a "soft" yellow one. What are you guys using?
I use Surhold brushes and other implements ... they require Shurhold stick. The brush we use the most that is always on/near the boat is the Hammerhead. Other brushes we use are 10" size of various softness, they feel heavy especially on extended stick ... a 6" medium softness is probably what you need for non-skid deck and below waterline hull, the soft bristles for frequent washdowns of the hull and deck above waterline.
In seven years the Hammerhead proved to be the most versatile brush capable of cleaning the hull, deck, and dry sweeping the cockpit. Still good after seven years but showing signs of wear. All Shurhold brushes have soft bumpers all around to guard against hard bumps and scuffs.
FWIW, here is the link to their line of boat brushes .... https://shurhold.com/marine/shurhold-system/brushes
I use this handle:
https://www.westmarine.com/buy/west-marine--telescoping-deck-brush-handle-admiral-3-6--12830956?recordNum=1
with the brush from this:
https://www.westmarine.com/buy/west-marine--stowaway-3-0-deck-brush-kit--12830840?recordNum=1
I learned the hard way that the rubber grip on the end of the stowaway loosens up and comes off when using it in the water.
When it's not in use, this combo sits in a set of clips on the side of the engine compartment, so it stays out of the way.
This stuff:
http://www.starbrite.com/item/non-skid-deck-cleaner-with-ptef
Also does a great job of getting rid of heavy dirt, and making the nonskid easy to clean with just a hose for normal footprints, etc.
I can safely say I never thought about taking a bristled brush to the hull. I assumed that was a no no and always used a sponge. That's good to know that you can do it tho. Thanks for the link
  • 2 years later...
  • 3 weeks later...
Surehold yellow works for me. Scrubs out those dirty footprints.
