Juan
Alarm goes off and it rpms go down momentarily
I have a 2002 chaparral Signature 260 with a 350 mercruiser 5.7L. After a valve job (I.e. cylinder head cracked and boat had no power), wiring harness replacement, and raw water pump replaced, IAC motor replaced, and a few other things that I lost track of. We keep having an alarm go off and the boat loses speed momentarily. It’s a random alarm, I have not found any pattern and it happens at any point in time. I will say that sometimes it takes a little while until it starts, most times not until we get out of the dock. So when accelerate. After being on a plane for a while it does not happen anymore.
FYI: I tried disconnecting the drive lube reservoir already. The one other thing I’ll add is that I my oil pressure gauge is broken shows max (80) but when connected to a computer it shows normal levels.
Any help with this will be appreciated... I’m tired of spending money on this. ($7k+) I’ve had 3 mechanics look at it and they can’t figure it out.
Thank you !!
Thank you !!
Steady alarm or two beeps per minute?  W
Steady. One beep and the engine revs down for the length of the beep (1 second beep)
I have the same boat.  How many hours on yours?
i recentlybhad the the same issue and it was connection issues with the wire harness.
537 hours. What do you mean by connection issues with the wire harness? Can you please expand on that? Thank you!
As the beep is steady and does send the engine into it's power limiting mode, then the ECM see's the issue as critical, which limits the possibilities quite a bit. Sure, there may be a wiring issue, especially on a 2002 boat, so look for corrosion at all the wire termination points, trans-pac connectors, and gang plugs. Also look at the ECM error code list below focusing on the alarms marked constant. My guess is that your raw water pump is beginning to fail and it's low output pressure trips the low pressure warning sender once in a while. W
Warning System
The engine warning system incorporates an audio alarm and, if installed, a SC1000 System Monitor. When the key switch is turned to the ON position, the audio alarm will momentarily activate to test the warning system. The alarm should sound once if the system is operable. This table is a quick guide, showing what warning output will accompany a fault.
Fault
SC1000
Audio Alarm
Available Power
Cam Sensor
Yes
2 Bp/min
90%
Open or short, engine must be cranking to set this fault code.
ECT CKT HI
Yes
2 Bp/min
90%
Open
ECT CKT LO
Yes
2 Bp/min
90%
Short
ECT Coolant Overheat
Yes
Constant
6-100 %
Engine guardian overheat condition
EST 1-8 Open
Yes
2 Bp/min
NA
Coil harness wire open
EST 1-8 Short
Yes
2 Bp/min
NA
Coil harness wire short
Fuel Injector 1-8 Open
Yes
2 Bp/min
NA
Fuel injector wire open
Fuel Injector 1-8 Short
Yes
2 Bp/min
NA
Fuel injector wire short
IAC Output
Yes
2 Bp/min
90%
Only with rpm
Knock Sensor 1
Yes
2 Bp/min
90%
Alarm sounds for 20 seconds in NEUTRAL and indefinitely in gear.
Knock Sensor 2
Yes
2 Bp/min
90%
Low Drive Lube Strategy
Yes
Steady Bp
0-100%
Low oil in sterndrive
Low Oil Pressure Strategy
Yes
Constant
0-100%
Low oil pressure strategy
MAP Sensor 1 Input High
No
2 Bp/min
90%
Short, no visual on SC1000
MAP Sensor 1 Input Low
No
2 Bp/min
90%
Open, no visual on SC1000
MAT Sensor
Yes
2 Bp/min
90%
Open or short in MAT circuit
NOTE: If any 5v sensor becomes shorted to ground the engine will not start. If the engine is operating when the short occurs the engine may stop operating and will not start.
Fault
SC1000
Audio Alarm
Available Power
Oil PSI CKT Hi
Yes
2 Bp/min
90%
Short, defaults to 51.7 psi
Oil PSI CKT Lo
Yes
2 Bp/min
90%
Open, zero oil pressure
Overspeed
Yes
Constant
RPM Limit
Engine over rpm limit
Port EMCT CKT Hi
Yes
2 Bp/min
90%
Open, defaults to 32 degrees F (0 degree C)
Port EMCT CKT Lo
Yes
2 Bp/min
90%
Short, defaults to 32 degrees F (0 degree C)
Port EMCT CKT
Overheat
Yes
Constant
6-100%
Overheat condition, 212 degrees F (100 degrees C) limit
Sea Pump PSI Lo
Yes
Constant
6-100%
Low water pressure strategy, defaults to
43.4 psi
Sea Pump CKT Hi
Yes
2 Bp/min
90%
Open
Sea Pump CKT Lo
Yes
2 Bp/min
90%
Short
STB EMCT CKT Hi
Yes
2 Bp/min
90%
Open, defaults to 32 degrees F (0 degrees C)
STB EMCT CKT Lo
Yes
2 Bp/min
90%
Short, defaults to 32 degrees F (0 degrees C)
STB EMCT CKT
Overheat
Yes
Constant
6-100%
Overheat condition, 212 degrees (100 degrees C) limit
Steer CKT Hi
Yes
No
No
Open and short
TPS1 CKT Hi
Yes
2 Bp/min
90%
Short, signal to 5v+, engine will not start. Refer to data monitor screen.
TPS1 CKT Lo
Yes
2 Bp/min
90%
Open
TPS 1 Range Hi
Yes
2 Bp/min
90%
Above 4.8v, 994 counts
TPS 1 Range Lo
Yes
2 Bp/min
90%
Below 0.5v, 35 counts
Trim CKT Hi
Yes
No
No
Short, high range, visual warning on SC1000 only.
Trim CKT Lo
Yes
No
No
Open, low range, visual warning on SC1000 only.
5 VDC PWR Low
Yes
2 Bp/min
varies
Short any 5v+ to ground
The main wire harnesses are notorious apparently for being lose and causing power drops and faults.
With the boat running, wiggle it and see if you get the alarm and the power dump.
 So very true.
The main multi pin plug connector on the engine is a good first step check. For intermittent problems. While idling & moving in F N R.
