HELP BILGE PUMP NEEDS TO BE REPLACED CANT GET TO IT
I HVAE A 350 BRAVO 3 AND I CANT REACH UNDER THE MOTOR TO GET TO THE BILGE PUMP GOT THE FLOATER BUT
NO WAY TO REACH PUMP  BOUGHT A NEW ONE HOW MUCH DEPTH CAN I DRILL A NEW SCREW IN THE FRONT OF THE ENGINE
BEFORE I DO MORE DAMAGE THRU THE HULL  ?  ANY HELP APPRECIATED  DO I HAVE A 1/2 INCH OR 1 INCH ?
THNAKS
Most chaps have a bilge pump mounting plate that has two screws up front where you can get to them. The pump mounts to that plastic plate, but you must remove the plate and pump as an assembly before you can access the pump screws. Can you attach a picture of your installation?  If your ride does not have the plastic plate, you may want to add one, leaving the pump in the stock location, lower in the bilge.  W
