Par
Fuel gauge dead
Help the fuel gauge on my sig 350 2006 stoped working. This is the connections to the switch that I choose which tank to show. If someone withe the same model would be so kind and check ther switch/ breaker and se if something is missing. Or if someone have other suggestion how to check cables
thanks for help  Par
Edited by Par
All text didn’t appear
That looks like it may be missing a wire. The yellows are likely grounds, the blues are the signals from your fuel senders, and the red is +12VDC for a backlight in the switch I assume. The switch will simply switch between which blue wire is connected to your fuel gauge. I’m not sure, but should there be a sixth wire which connects the signal to the fuel gauge? Maybe the red isn’t a backlight and goes up to your fuel gauge
You should be able to disconnect each wire and test it with a multimeter to confirm my assumptions. The voltage you find, or don’t find on the blue wires can also help diagnose whether it’s a fuel sender issue, dead switch, or dead fuel gauge.
thanks for help  Par
Thank you. Finally found two loose wires. So problem solved
21 hours ago, Pops said:
Hope this helps
