dh20
2010, 206 SSI with a 4.3 Merc, Alpha 1
Can someone confirm if a heat gauge is part of the instrument panel on a 206 SSi... also do all Mercruisers have guardian mode as standard feature.. (not just the alarms) but the reduced power feature should something go wrong.
The smart craft criteria is all inclusive per that attached worksheet. Alarm sequence, constant/critical, intermittent/informational and power limiting as indicated from 10 to 90%.
Engine Guardian System
General Description
Engine Guardian is the focal point of the self-diagnostic strategy on these engines. It helps
protect the engine from possible damage that could result from several faulty conditions.
The system monitors the sensors incorporated on the engine and if a malfunction is
discovered, a fault description is stored in thePCMand available power is normally reduced.
By ensuring that engine output is at a low enough level, the engine is better protected from
thermally induced failures.
For example, if an open or short is found in any sensor, available power will be reduced to
90% of total, the AudioWarning System Alarmwill sound 2 beeps perminute (2 Bp/min) and
the Smartcraft gauges will display a warning lamp. In a seawater pump pressure low
condition, the maximum rpm will vary with the pressure and temperature of the engine and
could be limited to idle in extreme cases of overheating, a constant beep will sound and
IMPORTANT: Engine Guardian cannot guarantee that engine damage will not occur
when adverse operating conditions are encountered. Engine Guardian is designed
to warn the operator of an adverse condition and to reduce power by limiting rpm in
an attempt to reduce possible engine damage. The boat operator is ultimately
responsible for proper engine operation.
SERVICE MANUAL NUMBER 36 GENERAL INFORMATION
90-864573 FEBRUARY 2002 Page 1A-25
Warning Chart
The engine warning system incorporates an audio alarm and, if installed, Smartcraft
Gauges System. When the key switch is turned to the ON position, the audio alarm will
momentarily activate to test thewarning system. The alarm should sound once if the system
is operable. This table is a guick guide, showingwhat warning output will accompany a fault.
Fault Smartcraft Gauges Audio Alarm Available Power Description
ECT      CKT HI                  Yes 2 Bp/min             90%              Open
ECT      CKT LO                 Yes 2 Bp/min             90%              Short
ECT      Coolant Overheat  Yes Constant           6 - 100 %   Overheat condition
EST 1   Open 1                      Yes 2 Bp/min            100%         Coil harness wire open
EST 1   Short 1                      Yes 2 Bp/min             100%         Coil harness wire short
Fuel Injector 1-7-4-6 Open Yes 2 Bp/min            100%          Fuel injector wire open
Fuel Injector 3-5-2-8 Open Yes 2 Bp/min            100%          Fuel injector wire open
Guardian Strategy              Yes Constant         0% - 100%     Protection Strategy
IAC Output LO/HI 2                Yes 2 Bp/min             90%                   Open
Knock Sensor 1 Lo             Yes 2 Bp/min              90%                   Open
Knock Sensor 1 Hi              Yes 2 Bp/min              90%                   Short
Low Drive Lube Strategy     Yes Constant            100%         Low oil in sterndrive
Low Oil Pressure Strategy   Yes Constant          0 - 100%      Low oil pressure strategy
NOTE: If any 5v sensor becomes shorted to ground the engine will not start. If the engine is operating when the short occurs the engine may stop operating and will not start.
NOTE: 1 GM EFI ignition system failure open or shorted, driver will flag EST 1 fault.
NOTE: 2 TPS must see 5% throttle then back to 0% to flag IAC fault.
NOTE: 3 2-wire sensor open will read sensor Hi on scan tool.
NOTE: 4VDC PWR Low - if shorted or no voltage engine will not start; if VDC PWR voltage falls velow 22 volts will set sensor faults.
NOTE: 5 Shift Switch - will activate code when engine rpm are above 3500 rpm and 40%
load.
GENERAL INFORMATION SERVICE MANUAL NUMBER 36
Page 1A-26 90-864573 FEBRUARY 2002
Warning Chart (continued)
Main Power Relay Output           Yes                 No N/A           Engine will not start
Main Power Relay Backfeed       Yes                No N/A            Engine will not start
MAP Sensor 1 Input High            Yes             2 Bp/min 90%   High voltage or short
MAP Sensor 1 Input Low             Yes             2 Bp/min 90%    Open, no visual on
SC1000 Oil PSI CKT Hi               Yes             2 Bp/min 90%    Open, defaults to 50.7 psi
Oil PSI CKT Lo                             Yes            2 Bp/min 90%     Short, defaults to 50.7 psi
Overspeed                                   Yes            Constant       rpm limit Engine over rpm limit
Pitot CKT Hi                             No                    100%              Short or high voltage
Pitot CKT Lo                            No                     100%                         Open
Sea Pump PSI Lo                  Yes Constant     6-100%
GuardStrat Sea Pump CKT Hi  Yes  2 Bp/min     90%                   Open - 0 psi reading
Sea Pump CKT Lo                 Yes 2 Bp/min          90%                   Voltage high or short
Sea Water Temp                        No          N/A                            Defaults to --31 degreesC
Fuel Level #1 No                                                      N/A                           Only if turned on
STB EMCT CKT Hi                     N/A        N/A         N/A                                N/A
STB EMCT CKT Lo                    N/A         N/A        N/A                                 N/A
STB EMCT CKT Overheat         N/A         N/A        N/A                                  N/A
load.
90-864573 FEBRUARY 2002 Page 1A-27
Steer CKT Hi                                       No                         100%         Short or high voltage
Steer CKT Lo                                       No                         100%                           Open
TPS1 CKT or Range Hi              Yes 2 Bp/min                   90%         Short or high voltage
TPS1 CKT or Range Lo              Yes 2 Bp/min                  90%        Open or low voltage
Trim CKT or Range Hi                Yes No                           100%      Open or high voltage
Trim CKT or Range Lo                Yes No                           100%                          Short
5 VDC PWR Low 4                            Yes 2 Bp/min                  90%         Short or low -
        engine may not start
MAT Sensor Hi                             Yes 2 Bp/min                  90%   Open -default to --32
        degrees F
MAT Sensor Lo                            Yes 2 Bp/min                  90%    Short -default to --32
        degrees F
Shift Switch 5                                       Yes 2 Bp/min                  90%               Open Circuit
load.
