chris85
Who owns a 2018 247 SSX or 2019 257 SSX?
Hey guys. I am about to pull the trigger on ordering a new 2019 257 SSX also known as the 247 SSX for the 2018 model year. I am really having trouble deciding on what engine to opt for. It will either be the 300 or 350 hp Mercury 6.2L. I am really trying to determine the performance difference and if its really worth spending over 5K for another 50 horsepower! I have viewed all the reviews that can be found online and I can only make reference to the Volvo 300 hp which was tested on this exact model and the Mercury 350 hp on the 2018 267 SSX, all reviewed by BoatTest.com. I know the simple answer is to get the largest engine possible however I just find it hard to justify 5K more for the same engine just with different software tuning...Just curious if anyone on this forum owns this particular combination and can chime in.
Thanks!
If you're gonna order a new $100k boat what's another $5k?  Personally I'd get the biggest engine they offer for that size boat.  That way no matter how many people or gear you have on board you will have plenty of power.  You'll get varying opinions on whether 300 hp is enough or not.  Its all in how each person drives and what their expectations are.
We have the 247 SSX.  It has the 300 VP (we liked the one in the dealers inventory).  Performs great.  With just a few of us on board we can hit 46 GPS.  Loaded with up to eight people, gear for the day, etc, knock just a few off that top to about 44.  Plenty fast for my family, that is an individual thing though.  We average a 30 MPH cruise around 4000ish RPM.  No need to be WOT most of the time...
No problem pulling toys with that many on board either.
One thing different, not sure if it makes a huge difference is the block each use.  For 300 and 350 VP use a 5.3 and Merc uses the 6.2 I believe.
We have had it since the latter part of July and love it!
Hi, everyone!   Newbie to the forum here.  I am also considering a new 2019 257 SSX.  Saw a BoatTest.com on an older 257 SSX  (2013?) with Volvo Penta 380 HP 6.2L and Duo Prop.
Checked the Chaparral home site Build program and it only shows Merc and VP to 350 HP now.  Is it just my antique software, or do they still offer 380 HP as an option?
I'm a bit of a horsepower junkie,  and the BoatTest.com specs on a 380 VP looked like just barely enough to get out of it's own way.  I'm looking for at least 53 mph WOT,  and a decent hole shot.
Seems like new 257 SSXs are pretty rare in dealers stock, especially without $$$ towers, forward facing  outdrives, or "surf" stuff.  I guess I'll have to order one.  Would highly appreciate hearing from people with experience on this model.
VAJeff ,  thanks for your input.
Thanks, ALL!
7 minutes ago, Rip5 said:
Not sure what specs you have seen, but it is not correct.
300,350 HP use the 5.3L GM Block
380, 430 use the 6.2L GM Block.
See here: https://www.volvopenta.us/marineleisure/en-us/products/motor-boats/ranges/aquamatic-sterndrive-gasoline.html
Thanks, Rip5 !!
Of course, you are correct!  I misread my source.  That explains a lot. 1) I'm an Old Salt  and 2) Why waste 6.2L on a 300 or 350.
I guess it's not just HP but torque as well.  My take is that in the big picture of the cost, 5k barely registers a blip.  If I'm ignoring my logic of used being a better bargain than new, I'm getting the bigger power plant in a brand new boat.
Back in 2008, the 496 HO option listed for 15 grand. I did not pay that much, but still.  I see the new Yamaha 425 HP outboard is 48 grand.
8 hours ago, Old Salt said:
Saw a BoatTest.com on an older 257 SSX  (2016?) with Volvo Penta 380 HP 6.2L and Duo Prop.
That model is really gone now.  The 2019 257SSX is identical to my 2018 247SSX.  I believe the 247SSX was brought out a little late in the year, and Chap already had a 257SSX in the 2018 lineup...
I am plenty happy with the 300HP, I have actually gotten her to a little over 48MPH (GPS) with just me on board.  I imagine the 350 may get you to the 53MPH you are seeking.  This is the same boat, https://www.youtube.com/watch?v=NCdZE09Kr0c, just 2 feet longer and about 800 lbs heavier...  It has a 350HP Merc and hit just over 50MPH.  You would be 2 ft shorter and at least 800 lbs lighter with the 2019 257SSX.  The VP will save you some weight too, since it will do the 350HP from a 5.3L block vs the 6.2 on the Merc.  There is a ton of torque in the VP too :)
Yes, this plays a huge part in the newer engines coming out...  I know mine does not really care how many people are aboard, it is always great out of the hole!  I believe that is attributed to the torque of the engine.  WOT may loose a few MPH, but it seems to always get up on plane just as quick.
Merc does!
I just double checked, the 380 is no longer there.  It was in 18 for the 247SSX.  We took dealer stock, which was the 300HP (although they also had 280 as an option in 18 too).  We were plenty fine with the 300 HP, did not feel the need to special order.
While I was doing that double check, I priced one out (I know it is MSRP), it is about $6K over the MSRP of what mine was.  I built it identical to what I have.  In 2018, mine built out to just North of $115K MSRP, and now it is just North of $121K.
Hello all,
I purchased the 247 SSX with the 6.2 350 horse merc. And am very satisfied with the boat thus far.  I only have 24 hours on it before it got cold but with 4-5 on board planes fairly quickly for a 5700 lb boat (6-8 seconds).  Max gps speed with 51-52 mph with sane load and fiberglass arch with Bimini.  Motor will cost about 50 bucks an hour to run on fuel with kids water sports.  Very stable and dry ride. When the big lake gets stirred up the 3-4’ chop doesn’t phase this thing.  Sticker was 117k left the dealer paying 83k.  Hope this helps your decision.
Hey Chris247SSX. What pitch prop set does your boat have with that engine? I know the 300hp has a 22" prop set, just curious what the 350hp engine that you have comes with.
On 10/27/2018 at 9:33 AM, Chris 247SSX said:
Hello all,
Congrats!  You will love the boat :)  Sounds like at WOT the 350 will get about 4 to 6 MPH more than my 300.  For me, once I am hitting mid to high 40's, I am just fine.  That may account for 5% of total run time too...  Most of the time, I am cruising around 3800 to 4000 for 29 to 31 MPH on average...  Burn is about 10 GPH at that speed.
It is a pretty dry ride, and handles chop just fine!  Really holds great in sharp turns as well.  We just reached the 50 hour mark, and will be getting it to the dealer soon for the 50 hour service.  Will have them get it set for a few months of winter lay up at that time too.
Hello all,
That's awesome.  I have to say, looks like you made out pretty dam well!  You've peaked my interest now with those numbers and not just the deal you got, but the $50/hour in fuel is very interesting.  Would love hear some details as to how you got to that figure, if you have time at some point.
But what's really interesting is that you got $34K knocked off of a brand new boat that was retailing for $117K...that's almost unheard of.  Good for you!  But it begs the question: what kind of profit margin/markups/losses are either the dealer and/or Chaparral taking on this sale?  If the dealer was able to knock off $34K, did they take the loss on that boat?  Or did they share it with Chaparral?  Let's just say the dealer did and made the minimum conceivable and call it $3K just for argument's sake, then they paid Chaparral  $80K, what are Chap's cost/profit margins in this case?  What would it cost them to build that boat factoring materials, parts, motor and all the labor, $50K?  Maybe more, maybe less but let's call it a $30K profit and I know there are many other costs associated but we'll keep it simple for now.  That means from $50K production cost, they tried selling it for $117K which is around 280% markup.  Seems right since the way these things are priced, there must be a rule of thumb that from factory cost to retail on the showroom floor is typically around 300% markup for margin of profit shared between the factory & dealer which allows them all that room to knock off so much money.  Pretty interesting stuff.
I purchased 2018 247 ssx  with 380 hp vp with folding arch start of summer we love the boat have 66hr and  now after 60 hr got broke in and  gained more hp  and faster out of the hole we cruise at 34 mph burns 12.9 gph top end 53 mph at 29 gph happy got the extra hp   very happy with trailer got the electric over hyd brakes wont buy surge brakes again no sliding down the ramp and faster stops pull it behind a suburban made equlizer hitch for it
Hello Hatem,
To tell you the truth I didn’t think I’d close the deal.  I was on vacation with the family at the lake and secured a 25’ cobalt bow rider rental for the week.  After day 2 the boat encountered problems and the dealer couldn’t fix or replace my rental and so I had angry children and wife. On that same lake was a Chap dealer where I had seen the 247 for sale for a couple months.  I went in to look and was floored at the 117k sticker.  I’ve bought many recreational toys and so I knew how much they’re marked up.  I told them give me their final and they cane back at 93k.  I knew it had been sitting there a while and fall was coming so I left my number and gave it 24 hours.  like any  salesman they called back and I went on offense and told them the wife capped my spending at 80k.  We settled 4 hours later at 83k and free valet service for rest of season and winter storage first year thrown in.
As far as the 50 bucks an hour in fuel use it was just my average with the time I had on it each time I fueled up.  Although like I said kids water sports (tubing).
Chris
I have a 236 ssx with a volvo 5.7 300hp. No way would I want less. More than enough power most of the time but fill it full of people and fuel pulling a skier or tube and you need more.
IMO, if the deciding factor is cost, find a used low hour, 1 or 2 year old boat. To me, horsepower is the difference between very happy with or just ok boat. That 5K will likely be returned come trade in time or selling. I have a 226 with a VP 350-300Hp. Performance with large load is excellent which is how we run most outings. I watch boats for sale all the time on line. Late model boats for sale tend to have the base or, one up from base, motors. HD pickups are similar. You rarely pay a price for buying more power , diesel / gas debate. More power, more value.
"the same engine just with different software tuning" is that an accurate statement? Can I tune my Merc 300 to get another 50 HP?
For Volvo Penta, the statement is only accurate for a small handful of Generation-V engines. Said differently, it’s not an available OEM upgrade for each and every engine Volvo Penta makes/made. I don’t know if Mercury offers something similar/identical. There are, though, non-OEM tunner options. Could be a dangerous path to follow unless confimed that the engine and drive are robust enough.
Thanks Curt, I am not touching it. I am very happy as it sits.
On ‎1‎/‎26‎/‎2019 at 1:38 PM, Chris 247SSX said:
Hello Hatem,
Chris
You scored big-time.  40% discount if my math is correct, that's pretty incredible.
Looking at that new style of Chaparral boats like the one in @247SSX's signature pic, you can see how they're squaring off the hulls a lot more with those corners at the round-over stern and swim platform, even the top of the gunwhale looks sharper than the previous style.  The also added that extra return around the hull like a built-in bumper on the side of the stern.  It's almost like the old style is making a full circle comeback, similar looks to the style and looks of @Denny's boat.
Some one some where told me that starting with the 247 it represented a new Chaparral in that they poached a top designed from Sea Ray and this is the first boats influenced by him. You can see it in the interior as well.
1 designer for several makes & models.  Oldest way to reduce overhead  consultant fees.  Back in the 1930 & 40s  I designer did a lot of  different makes & models   I can not recall his name.
Sad
Yeah, all they would need to do is make the transom more vertical, add a little teak, and enclose the bow.
She is a good looking boat, nice lines!
Going to the Detroit boat Show this month, hopefully Chap. will be represented, and I can get a closer look.
Denny.
