Skiingthebumps
Alpha or Bravo Drive
Bravo drives the water pump is located on the right side of the engine. Alpha drives the water pump is located in the out drive.
They look different. Where is the raw water pump? Down low, under the starboard front of the engine? Then it’s a Bravo drive. Twin counter-rotating props? It’s a Bravo 3 drive.
Google a picture of each  easy to see the difference
That's going to be an Alpha drive.  Just the 1.62 ratio tells you and the 4.3 on a small boat won't have a B1 or B3.  Bravo drive is much beefier looking and of course the instant you shift the boat, it is immediate evident when you have an Alpha.  Alpha is a substantially lesser technology which shifts hard into gear versus the Bravo which you can't really feel the shift.
