Fishstick
Cabin Heat during Winter Question
Hi,
I've been reading through some of the old threads on winterizing techniques (our first season to winterize) and saw several posts on leaving the cabin heat on during winter, unless I mis-understood the posts.
I got to thinking, we leave our heater on in our mobile home on around 55 degrees when we aren't there and now wondering if I need to do the same for the boat?
Is there any reason to leave the cabin heater on during winter and if so, what temp?
Thanks in advance!
I assume that your boat is sitting in the water for the winter.
I don't do what would be winterizing with antifreeze in the water system in the cabin, so what I do is turn the cabin heat on if it is going to freeze. The lowest it will go is 65, which will keep water lines from freezing. I do empty the lines, water heater, and tank. I don't leave it on all the time just if we are going to have a freeze.
Where you are it gets colder than were I am, so I would probably run the antifreeze through all the lines. With the cabin heater you can run into problems if the water in the lake freezes.
