TexasPilot71
Engine noise - “popping” or “missing”
Well here's my 2 cents. Secondary ignition problems don't show up within a norrow rpm range, they are more susceptible to engine load and get worse as load increases. Not a camshaft as they also worsen under rpm and load along with weak valve springs.Is it popping from intake or exhaust? Next I would get a DVOM and find the signal wire on the throttle position sensor. Unhook the cable and sweep the throttle plate open to close. Use a tpin to backprobe the wire. With key on you should see a smooth increasing and decreasing voltage sweep. You are looking for approx half a volt closed and 4.5 at full open.If anything looks un ordinary you can also take the sensor off and do an ohm reading across the supply and signal terminals. When installing make sure your base voltage reading remains the same. If that checks out I would next get a good timing light and check your base and total timing and also watch for any odd variations as the timing increases and decreases. You should not see more than 34 or so degrees of total timing. This may be very difficult to do but you can do it in neutral. If you see the timing wigging out it could be an ignition module issue. Hope this helps.It doesn't sound like an engine mechanical issue. Also a crank sensor usually only acts this way when there is debris on the signal plate and won't resolve under higher rpms. JK.
No codes avail on the engine ?
Last check. See if the throttle linkage has rubbed thru a ignition wire at that 1 lever rpm place.  300 rpm dead spot is very odd. Need a GREAT mechanic on this one.
I would expect a HUGE BILL to find this weird one.
Good advice, thanks!  I'll show this to my mechanic as it's a bit above my head.
I don't have a code reader, but I have a Vesselview 7 and it's not showing anything.  I suspect it should show any codes thrown, but I have not seen one yet.  After all, it runs off the diagnostics port.
well a similar issue on a thread here reported the exact symptoms and found to be a
"The problem was a bad fuel pressue regulator. Mechanic installed it last week. Boat runs better then ever. Good luck!"
Run a pressure check. Popping noise is lean condition.
Thanks for the link.  That's exactly the first thing we're doing on Saturday.  Checking the fuel pressure.  Praying that's it!
25 minutes ago, BajaDriver said:
I’ll keep my fingers crossed
Thanks!  I ordered a pressure regulator today just in case.  If not, I can just send it back.  Amazon!
Fuel pressure is good. No obvious vacuum leaks. Leaning toward a bad tank of fuel. Going to install a fuel/water separator filter, maybe hook up a fresh outboard tank of fuel and see if it doesn’t clear up. If not, then next steps will be injector cleaning.
Tiny band of rpms ?  Vibration of electrical ignition wire getting zapped  / touched to a ground point ?  or even a loose connection ?  Corroded connection ?
Does it miss at the same speed & way in Neutral ?
No popping in neutral.
And after riding with my mechanic yesterday, we discovered it’s popping even above the original 3600-3900 band Where I heard it. So anything above about 3500 RPM under load will produce the popping.
The injectors can be tested individually while still installed with a test pigtail and a Merc hand held. I'm still leaning toward a coil. W
Dang it! Well fuel, injector, etc.
Pull all the spark plugs. Look for the odd color or chipped insulator. It could still be a bad rotor or cap. Long run of baddies in stores ?
Some body has to eliminate Fuel or electrical system.
What happened this week end ?
Last weekend I replaced cap, rotor, plugs, wires, and fuel filter.  No better.  This past weekend we hooked up a pressure gauge and got normal readings while the engine was "popping".  The plugs I removed last weekend all look good except a few looked like they might have been running a little lean (grey color...not more "burnt" like the others.  They were only about 18 months old.  Mechanic looked at them and agreed.
Thanks.  Is there any way to test the coil or the crank position sensor?  How about the injector test?  Pigtail?  Merc hand held?  Never heard of them.
You put a fuel pressure gauge on the fuel rail, then turn the key on without cranking and note the pressure.  Let's say it's 43 psig.  You then hit the test button on a specific injector and note the pressure drop.  Let's say it's 3 psi.  Then you repeat the process with the remaking injectors.  If they are higher or lower than the average then you have a bad actor.  The test just opens the injector for a precise period of time as commanded by the hand held.  Injectors are expensive and if you find a bad one you change it.  No reason to fool with the remaining 7 as they tend to be very reliable.  W
What is this "test button"?  Is it on the injector itself, or are you talking about a piece of diagnostic equipment?  I do get 43psi at "key on".
If you send me a valid e-mail address I will send you the test procedure direct from the Merc manual. Simply put, you unplug each injector, and plug on the test pig tail. Then the other end of the pigtail gets connected to the hand held scan tool. You establish a base line fuel pressure, and then with the key off, you depress the test button on the hand held which fires that injector for a specific pulse width (duration in milliseconds). You then record the new fuel pressure reading and repeat the procedure for the remaining 7 injectors. Too much pressure drop indicates a sticking injector which closes too slowly. Too little pressure drop indicates a partially plugged injector. No pressure drop indicates that the injector has failed electrically, is plugged solid, or is stuck fully closed. W
"Semi" Update:
I've run a full tank through the motor, and I'm about half way through another tank.  Still no improvement.  Called Mercruiser just an hour or so ago.  Michelle was awesome!  I explained the issue and she asked me about the fuel filter in the cool fuel module.  She asked if it was black.  I explained that there was quite a bit of black on it (see photo).  She explained that the Gen III cool fuel module had a known problem.  It's been discussed on several boating sites, and I remember reading about this...but essentially, they painted the inside of the cool fuel module with black paint.  Fuel (more than likely ethanol in the fuel) delaminates the paint causing the black filter, and eventually this paint clogs the injectors.  I asked her if that would cause the "popping" and she said that it was highly likely because the clogged injectors would cause a lean condition.
She told me that Mercury would cover the parts if I would cover the labor to replace the cool fuel module (includes two pumps, regulator, housing, filter, etc.) AND 8 new fuel injectors!  Only catch is that I have to use a Mercury service center.  No problem as we have one right at the marina.  How's THAT for service?  Fingers crossed this will do the trick.
Give it a shot. Just doesnt seem like that would be the cause of such a narrow rpm band issue.
Totally agree.  A true popping of leaness ?  for 300 rpms only ?  What controls the fuel mixture ratio at rpm & causes leaness.  I would almost go back to a injector startin to die slowly.
But only a 300 rpm range ?
Plug wires rerouted INCORRECTLY ?   Inductive cross firing ? But I never heard of only a 300 rpm band in the middle or the range.
Where is my Sun Ignition tester with a oscilloscope to watch the plug firing patterns & timing & strength. ……...Old / ancient school.   :beat-dead-horse:
Hold everthing………………….. November 11 post said The popping no goes on anytime above 3500 rpms with a load.  It is  going now.
Lets do the shorting out …….1 sparkplug at a time...…..test. The bad cylinder parts will have the least rpm change  ??  or at least a different one ??
Like the new pump coming with no paint clogging the pump at higher RPMS.
Let me clarify via a little update. Turns out it is “popping” even at higher RPMs. It was just hard to hear from the helm because the engine noise was of course louder. My mechanic friend who was sitting with his legs hanging in the bilge told me it was happening at ALL rpm settings. And tonadd to the clues, last weekend I also noticed some surging around 4200 rpm. Only about +\- 100RPM but I could noticeably feel acceleration and deceleration matching the digital tach.
Yep, see my above reply. Turns out it wasn’t such a narrow band as I thought.
The paint clogged pump can hold 45 PSI but the GPM is being reduced after 3500 rpm.  Paint the pump insides.
Good call Mercruiser on the expenses.
