Long Point
2004 Chaparral 230ssi Engine monitor alarm fault
Own a 2004 Chaparral 230ssi. 350Mag Mercruiser sterndrive.  Looking forward to spring and getting it prepared for Summer.  Over the last two years I have had an engine monitor fault.  When the engine is cold and I turn the key, there is no "Beep" from the peizo buzzer.  If I run it a few minutes and turn it off the alarm works turning the key.  Will sound every time throughout use.  After shutting down usually overnight then it does not sound.  Any reports of the Peizo causing this?  I have gone over all connections.
Weak battery ?  Running the engine brings the battery voltage up ? Bleeds down over night ? Simple to check ?
