rbh1
Signature 350 Carpet
Quote
I just purchased a 07 sig 350.  Looking for cockpit carpet.  I see a few web sites that have the pattern, however they all show the two holes for the table.  It looks like in 2006 they changed the configuration to only one leg on the table. Hence one hole. any help would be great.
Call Cecil Marine.
Too bad they stopped making the carpets. I guess it is a good thing I got my replacement when I did.
Would you know of any company out there that would have the pattern for an 07?  Seems like the the older one have the same patter except one for the table.  I don't have the old carpet to use for a template.
I checked snapincarpet.com and they only have the old version with the two hole cut out.
Infinity luxury Woven Vinyl. Its the only way. Look at "better then teak 2" I will be buying it for my cockput this year. I've done my homework. Its excellent against wear and staining. Snapincarpets.com  should have. Double check or call them. Sometimes not listed online.
I spoke with two separate sales people at  Snapincarpets.com both advised they do not have the template for the 06 or latter with the one hole.  I find that hard to believe as it has been the same from 06 through  09 and continued with the Sig 370.  I also like the "better than teak II"
We bought vinyl backed carpet from Amazon. Took it to a local carpet cleaning business that does edging with our old carpets and they made us new carpets that fit perfectly!
Buy outdoor poolside carpet.  It is perfect.  Have it edged  as jdbragdon did.
Carpet is cooler than others. barefoot stuff.  washable if wined.
good evening, I just saw your post and that you are located on Long Island,NY. I live there also and replaced my 2007 Signature 330 carpet last season.I was recommeded to JTC Carpets here on Long Island. i dropped off my old carpet as a template and new were made. fit was excellent and price very reasonable. Also used a new backing instead of the black rubber and new did not stick to deck. Very nice people. Phone # 631-277-5107
Problem is the boat does not have the original carpet.
Make a template yourself and take it to a carpet shop.  You aren’t going to find an out of box solution for the missing carpet.
We had new flooring installed in our 2006 350 without the old carpets available for comparison.  A competent installer should be able to make the appropriate templates for your flooring needs.
Snap in carpets will use your template also and the carpet appears to be the same as factory original.
We own a 2006 350  Signature and have replaced the carpeting when we purchased it in 2013.  We used https://www.snapincarpet.com/, I think you will be very happy with their work.
We too have a one post table in the cockpit seating area.  Snap in did not have a pattern so I took in teh old ragged pieces and the owner, John, made a pattern.  They should be able to take care of you with your choice of carpets!
Bob
Bob
Bob I wish I would have seen your post sooner.  I would have asked Snap in carpet to use your pattern.  I paid a local guy a bit moor to make a pattern and supply the carpet.
