Fishstick
Kohler Generator Maintenance
My 95 Signature 310 has a Kohler generator in it, my guess is it's the original.
It ran fine last season and this past weekend it cranked right up after storage.
My question, do I need to annually change the coolant and oil on the generator? Are there any special things to do or watch out for?
Just like the boats engine. The oil should have been changed out last fall with the filter. Fuel filter should be changed and the impeller should be checked too.
I would also check its battery and connections.
It is a closed system with fresh water used to cool the closed system.
So my kohler gen has clear coolant. I can not find it anywhere and need to add... any suggestions what is compatible?
You can get 50/50 mix just about anywhere.
yes you can get 50/50 anywhere but where can you find clear collant?? I have always been told mixing colors of coolant is not advisable.
Perhaps start with the model and year, and determine what Kohler specifies and use that. Eliminates guessing.
There is also a anode on the heat exchanger that you should change as needed.  Alot of people dont know that and it corrodes to nothing and then provides no protection.
