wmulford
Bow Seat back cushion removal
I have a 2009 226 ssi and the front bow handle bolt came out. I believe I need to remove the front bow cushion to be able to screw it back on.  Does anyone know how to remove the front bow cushion?
It can be held in a number of ways. If you can get at it form underneath, it maybe held in with screws .
If not then they sometimes have corner straps that are sewn on to the underside of the cushion  and held on with snaps.
And another way, is with velcro.
If you cannot get at it from the bottom start lifting the corners.
Finally, if there are cushions on either side of it, take your hands and spread them apart, and look for tinny holes along the sides, if there then it was held in from the top with phillip screws, locate them and unscrew them, and your cushion will come out. Good luck.  Denny.
